It Pops
Old Aug 15, 2010 | 08:58 PM
Marv02's Avatar
Marv02
Default It Pops
Well it's back together I think I fixed the bending push rods Issues.
Still not running I found the New fuel pump was not putting out any fuel pressure so I put the old one back in.
The motor still not running but at least I can hear it pop once in a while If I retard the timing it pops more.
It sounds like it trying to start I need to go out a get a fuel pressure gauge and see how much pressue I getting to the injectors.
The cam is dead on the motor in TDC both valve are closed, Rotor is pointing where ity needs to be, getting compression, Have strong white spark.
I pulled #1 Injector it has fuel on the bottom of it but is there enogh pressure to make thing work.
With any luck I have running soon.
