Where can I find...
Old Aug 16, 2010 | 05:13 PM
tehcarguy's Avatar
tehcarguy
Default Where can I find...
Where can I find new tint for the glass top? The tint that is on it now is wrinkled...
Old Aug 16, 2010 | 05:20 PM
stevie1dr's Avatar
stevie1dr
Save yourself alot of grief and time and just take it to a professional tint shop. It will be done properly, faster, cheaper, and without bubbles.
Old Aug 16, 2010 | 05:24 PM
tehcarguy's Avatar
tehcarguy
Is it even worth spending money on new tinting? How much of a difference would it make if I just ripped the old tint off and left it perfectly clear?
Old Aug 16, 2010 | 05:48 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
The tops I have seen (like mine) are already tinted.
Old Aug 16, 2010 | 06:26 PM
bczee's Avatar
bczee
Not to side track this threaed.. but my top cracked.. it it worth saving to get repaired or just dump it..
is it worth selling for a core for anyone to use?
Old Aug 16, 2010 | 06:28 PM
BADDUCK's Avatar
BADDUCK
you can get a refurb top and trade in your frame
Old Aug 16, 2010 | 06:31 PM
ElvisGraceBo's Avatar
ElvisGraceBo
I removed my tint rather easily. It didn't leave any residue and came off clean.
I would suggest a professional do any reapplication of tint after the old stuff comes off. You have to be very careful with these tops as they are not actually glass, but lexan or poly something. I had my old top tinted by a shop and he pre cut the tint from the outside and left razor marks in my top.
The tint makes a big difference as far as heat and light blockage. The factory tint is very light, although with the AC on it doesn't get too hot. It does let much more light into the cabin however.
My opinion is that if a professional tint shop will tint it without the wrinkles or debris in it, let them do it. If you don't have a pro do it, I would just leave it alone. It's not easy to heat shrink that film around the contoures of the top. And you have to be careful pre cutting it on the outside because if you go too deep you will cut the top from the outside. Also the intallation on the inside of the top is not easy unless you have done many many many before.
I have some pics on one of my posts showing the top with tint and without.
Old Aug 16, 2010 | 06:34 PM
ElvisGraceBo
[IMG][/IMG]
Old Aug 16, 2010 | 06:36 PM
ElvisGraceBo
[IMG][/IMG]
Currently I am untinted. But if I find the right place to do it, I will.
Old Aug 16, 2010 | 06:37 PM
ElvisGraceBo
There are places that sell just the glass replacement. I think I found one complete here for less than that.
Old Aug 16, 2010 | 09:46 PM
tehcarguy's Avatar
tehcarguy
That's exactly how the tint on my top looks right now. I guess I'll just remove it until I can find a place to do it for me. Thanks guys.
Old Aug 17, 2010 | 12:04 AM
grantar2's Avatar
grantar2
Keep your core
Old Aug 17, 2010 | 12:07 AM
grantar2's Avatar
grantar2
The top isn't glass, if tint was added it was a pep boys, job professionals wont touch it. They use heat guns with professional film and you can't do that with the plastic used for the top. If you strip it, mid america sells a liner that still lets you see out, but massively reduces heat and UV. Its about $30.
Old Aug 17, 2010 | 02:34 PM
tehcarguy's Avatar
tehcarguy
Thanks grantar. I know the top isn't made of glass, I just call it glass cause that's how I've heard it forever.
To Where can I find...
