Some Advice
Old Aug 16, 2010 | 04:22 AM
Wasso89's Avatar
Wasso89
Navigator
Default Some Advice
So I have a 89 Auto. The entire engine is OEM. and I need some advice on what the best upgrades that a reasonably cheap and easy to do to increase my power. Im not looking into turning my car into a drag beast or anything like that. I got a budget of $500 dollars. and please don't make fun of my low budget. Im a 20 year old college kid who works at Target. Believe it or not they don't pay so well lol
Old Aug 16, 2010 | 08:29 AM
Muffin's Avatar
Muffin
My advice is spend your $500. on maintenance and reliability items leaving mods for the future. In stock condition you have more than enough car to get you where you need to go at reasonable cost day in and day out looking dang good doing it. Meaningful mods require some serious coin when viewed from your student status. Be very happy with what have leaving the mods to the future.
Old Aug 16, 2010 | 08:34 AM
Pete K's Avatar
Pete K
You are in luck. This forum has been around for over 10 years, and has accumulated thousands of threads on modding an L-98 engine. High dollar, and low dollar. I am certain of this, as I have contributed to many. On the top right 1/2 of your screen (near the center) you will see the word search. Do advanced searches in the c4 tech section, and you will have weeks of reading.
Old Aug 16, 2010 | 08:37 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Look at my profile. There are some inexpensive mods I did on my 1989. Concentrate on exhaust first. If you can remove the precats and install dual outlet mufflers or muffler elims it will help. Remove the frisbee. Cut the air intake lid and buy a new filter. Install aluminum UD pulleys (March P&A # 4425). That will take most of your $500.
Old Aug 16, 2010 | 08:47 AM
Calderone's Avatar
Calderone
Take Muffin's advice first , i think its NOT what you want to read
but it will keep you out of trouble and you'll be happy to have your car.
If you modify you have old spark plugs,clogged fuel filter and dirty air filter it will get you nowhere,check the basics out first.
If everything is OK, i'll go with longtube headers and Roller Rockers.
Old Aug 16, 2010 | 08:51 AM
rodj's Avatar
rodj
Courtesy of Mr Vader
http://temp.corvetteforum.net/c4/vader86/minormods.html
Old Aug 16, 2010 | 11:38 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I have to agree. Most people don't pay enough attention to maintenance/upkeep. If you change the filters and fluids (all fluids) every couple of years, that alone will cost a couple hundred bucks. Throw in spark plugs, dizzy cap, coil, and other similar maintenance items and you've spent your $500.
If you've still got some left, look at your weatherstrip (over $500). Where do you rate staying dry vs having a bit more growl? What's your interior look like?
Exhaust (unfortunately) is something that will eventually rot out too. That's where the first real modification almost becomes a requirement.
FWIW: A well-kept, good looking car (paint, interior, engine compartment, etc...) should keep value up better than "cheap mods".
Old Aug 16, 2010 | 11:55 AM
Jimbo 89's Avatar
Jimbo 89
I too have an 89 auto, and the first thing I did was replace fuel injectors.
See sticky at top of page... I bought from Jon as most others have.
DO COMPRESSION TEST!!!
The next thing that happened to me was blown head gasket (very common). It was simply rusted out (80,000 mi.)
You can check my profile for other mods that WORK!!!
Old Aug 17, 2010 | 02:02 AM
Wasso89's Avatar
Wasso89
Navigator
To be honest I keep my car very well maintained i'd like to think. I change oil every 3000 miles and do a full fluid flush every time i change the oil same with the air filter. I know it seems a bit OCD. And I budget really well, the money I have is for mods exclusively. I have separate budget to keep my car tip top shape. I just want a little more power and maybe a more aggressive sound.
Old Aug 17, 2010 | 02:52 AM
Calderone's Avatar
Calderone
Check compression
Long tube headers
1.6 Roller Rockers
Old Aug 17, 2010 | 11:37 AM
GREGGPENN's Avatar
GREGGPENN
Then an exhaust system upgrade is your best option. It can change the sound while providing a bit more power. $500 probably won't get you headers with that UNLESS you find a used LT1 exhaust and buy painted headers.
Old Aug 17, 2010 | 01:04 PM
ch@0s's Avatar
ch@0s
I had an 86 Dual exhaust really woke it up.
Old Aug 17, 2010 | 03:07 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
As others reccomended do a search.
IIRC the one thing to wake up any engine is more air in and more exhaust out.
The L98 really wakes up with those things.
To Some Advice
