'96 code P0441 incorrect purge
Old Aug 16, 2010 | 08:00 PM
mmgood18's Avatar
mmgood18
2nd Gear
Default '96 code P0441 incorrect purge
Hello, Could anyone tell me what the usual cure for this is?
Old Aug 17, 2010 | 03:42 AM
toptechx6's Avatar
toptechx6
The purge solenoid is a common failure part, but there is only one correct way to troubleshoot any code, follow the fault tree in the factory service manual to eliminate other possibilities.
A quick test would be to check resistance across the two pins of the solenoid, if the reading is infinite (open) the solenoid is bad.
Old Aug 18, 2010 | 10:02 AM
JAKE's Avatar
JAKE
Yep, that's the way. As I understand it you'll need a scan tool that can command the solenoid to turn ON in order to run the full tree. Of course you'll need a digital volt meter and a vacuum gage too. IIRC the tree's not too complicated but does call for at least one specialized tool.
I'd also check all the vacuum hoses for leakers, disconnected, blockage, etc.
Jake
Old Aug 21, 2015 | 04:13 PM
Brentwood Sooner's Avatar
Brentwood Sooner
I had this code come up and also P0336 come up, are these codes releated?
To '96 code P0441 incorrect purge
