Timing Advance
Old Aug 19, 2010 | 12:37 PM
twotone84vette's Avatar
twotone84vette
Default Timing Advance
Hi All,
Would advancing the timing on an 84 from 6 degrees BDTC to 10 degrees require premium fuel?
Old Aug 19, 2010 | 04:44 PM
thedudeman321's Avatar
thedudeman321
No, but your computer will likely just retard it back.
Old Aug 19, 2010 | 05:00 PM
mbowers13's Avatar
mbowers13
From: https://www.facebook.com/groups/OrangeCorvettes/
You shouldn't get retard unless you get knock. I doubt 4 degrees would cause knock but it depends on the gas in it of course.
Muffin's Avatar
Muffin
Your computer will assume base timing is set at 6 degrees and work from there. When it senses ping the computer will begin pulling timing till pinging stops. Using 92/93 octane fuel will, maybe, reduce the amount of timing pulled but the net results will not be a power gain you will notice. At least that is my take on it.
Old Aug 19, 2010 | 05:04 PM
ggrassmid's Avatar
ggrassmid
I increase my 85's timing from 6 to ending at 14. I took it slow to see how things went. Started going up by 2. I run premium, I have not heard any knock, not saying the computer doesnt. The response in the car was a big difference. Other than that, I cant say it was a huge difference. I did this in conjunction with resetting the IAC and idle speed as well.
Old Aug 19, 2010 | 05:17 PM
Orr89rocz's Avatar
Orr89rocz
It will depend on the actual timing curve in the stock bin and the air fuel ratio at WOT/cruise.
You can advance base timing and not see any negative side effects like knock or any timing retard from the ecm. Then again you may not.
Leaving 6 inthe chip, and changing base to 10 means you add 4 deg over the entire spark table. That wont effect idle and may not have any impact on cruise timing but could have big impact on WOT
You may already ahve 34-36 deg in WOT at max rpm. 4 more deg could give you 38-40 which is alot of timing without premium fuel and even alot with 93 oct...
Without knowing what you have its hard to say what will happen. You need a computer scan while driving to test this, as you will have timing being pulled WELL before you ever hear any knocking.
93 oct gas will help prevent any detonation or knocking which SHOULD yeild more power everywhere. May not be a whole lot, but any aggressive timing curve on a motor for premium fuel is worth power.
Old Aug 19, 2010 | 07:07 PM
383vett's Avatar
383vett
Originally Posted by twotone84vette
Hi All,
Are you running regular now?
Old Aug 19, 2010 | 07:47 PM
ex-x-fire's Avatar
ex-x-fire
Remember if he has origanal heads (ancient camber designs) alittle timing will help. GM set the timing there so you could run on some pretty crappy gas that is out there. Also the CFIs have a map sensor, so advancing the timing will add alittle more vacuum, which may add some mpgs. Make sure the egr system works good, as that helps w/ part throttle spark knock.
Old Aug 20, 2010 | 08:03 AM
twotone84vette
383vett,
Started using premium after the timing advance. Egr is gone.
Old Aug 20, 2010 | 06:22 PM
aklim's Avatar
aklim
I generally don't think much of timing advances. What it does is advance the timing across the board. ECM still assumes you have 6 degrees. At some points, you might be able to use more timing but at others, not so much. It is better to have it done in the chip program so it can be done only at the points where you need to. At some points it might ping or even ping lightly and the ECM will retard the timing so any gains you got go to waste. Also, in the meantime, these repeated episodes might stress the block out.
To Timing Advance
