Heads for future blower
Old Aug 20, 2010 | 11:06 PM
matt_jahn's Avatar
matt_jahn
Default Heads for future blower
well Im in need of a head gasket and figured id do heads while im in there. right now i have lt4 hotcam and springs with 1.6 rr. and full exhaust. i would like to put a procharger on it eventually. what heads do you suggest? and what kinda horse power would you expect with that set up.
Old Aug 20, 2010 | 11:13 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can put bigger valves in and have them ported they will take the boost but by the time youre done your not far from a set of aftermarkets that will probably do the job better and will be new not worked over used ones. How much do you have to spend
Old Aug 20, 2010 | 11:15 PM
matt_jahn's Avatar
matt_jahn
well come tax season ill have a couple thousand, so im gonna do an intake too, if there is a good one out there, or i might port on mine
Old Aug 21, 2010 | 01:52 AM
tpi 421 vette's Avatar
tpi 421 vette
With a supercharger, you could probably consider a bigger head than you would normally consider being N/A. If you were to say consider some AFR 195's you might consider some AFR 210's if you have enough cam in it. Just an example. But you can consider a head bigger than you would think about being N/A.
To Heads for future blower
