Tap Size
Old Aug 21, 2010 | 04:54 PM
blkvette85's Avatar
blkvette85
Default Tap Size
I have a TPI set up that has been sitting for a long time. I want to rebuild it, but i found the treads on the fuel rail are messed up. Does anybody know what tap I need to fix the treads?
Old Aug 21, 2010 | 05:49 PM
JAKE's Avatar
JAKE
Originally Posted by blkvette85
I have a TPI set up that has been sitting for a long time. I want to rebuild it, but i found the treads on the fuel rail are messed up. Does anybody know what tap I need to fix the treads? Thanks
If you don't receive a quick response, just take one of the bolts to your local ACE and match it up. You'll probably have to go there anyway.
Jake
Old Aug 21, 2010 | 06:08 PM
blkvette85's Avatar
blkvette85
I need the size tap for where the fuel lines go into the rail fittings. The lines themselves
Old Aug 22, 2010 | 12:21 AM
JAKE's Avatar
JAKE
Oh, I see. Well, if no one knows, just take the fuel rails. That is unless you want to buy a complete deluxe tap set.
Jake
Old Aug 22, 2010 | 01:18 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
find someone around you that has a tap and die set.
Most sets come with a thread pitch gauge. use it to determine the threads per inch.
Then get a bottoming tap. Bottoming taps are not tapered, and thread the hole down to the end.
If you can't get someone you know to let you use their thread pitch bauge, take the fuel rail to a hardware store, and they can let you use one from a new kit.
Old Aug 22, 2010 | 02:34 AM
rodj's Avatar
rodj
16mm x 1.5 on supply
14mm x 1.5 on return
16mm on both on later cars ('88+ ?)
Old Aug 22, 2010 | 12:23 PM
blkvette85's Avatar
blkvette85
Thanks for the help guy.
To Tap Size
