idle at 500?
Mar 27, 2002 | 09:53 PM
idle at 500?
Whe nwarm and in drive my car will idle at 500. I heard that under 700 the batt. starts to discharge. Is 500 too low?
Mar 27, 2002 | 10:00 PM
Re: idle at 500? (Tim89)
I don't know about the battery discharging below 500, but I don't think it would be an issue since you surely spend a lot more time above 500 rpm than you do at a 500 rpm idle! As long as it dosn't want to die on you I don't see a problem.
Mar 27, 2002 | 10:08 PM
My 86 idles at 500rpm when warm. The instructions I have for setting the base idle say to set it to 450rpm when warm and in gear, so 500 sounds about right.
Mar 27, 2002 | 10:09 PM
My manuel states when adjusting TBI's it should adjust to 475. I've never seen that...but that is what the bhook says.
Mar 27, 2002 | 10:52 PM
Re: idle at 500? (JonM)
check the TPS voltage, but mine idles at 6-700rpm, yours may be a bit low but i dont see that its a major issue
Mar 27, 2002 | 10:58 PM
Re: idle at 500? (Mike263)
Thanks for the responses. Not somthing I will worry about.
Mar 28, 2002 | 12:48 AM
Cruise-In II Veteran
Flip the dash sw to "Volts" and see if it's charging. Unless you have an underdrive crank pulley it should be ok.
Mar 28, 2002 | 12:53 AM
Re: idle at 500? (65Z01)
hehe.... if i set my idle to 500, my car would just die. The cam requires about 650 or 700. I have mine at 775 when warm so that it's not toooo rough.
Mar 28, 2002 | 02:02 AM
Re: idle at 500? (Glock'94)
Don't feel bad! With my cam I have to idle at 900!
Mar 28, 2002 | 02:16 AM
Re: idle at 500? (Ezgoin721)
yeah, i'm not bad off at all.. other cams are much worse. I stalled it tonight once putting it into gear :). I should have it higher, but I like the sound of the low idle on a cammed car :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Mar 28, 2002 | 02:37 AM
L98 normal idle at 450-500. LT1s' idle higher
