MSD distributor wiring problems on 92 Vette
Old Aug 23, 2010 | 06:13 AM
AustrianVette's Avatar
AustrianVette
Default MSD distributor wiring problems on 92 Vette
Hello,
I had problems with my ignition. Sometimes the car didn´t start or it simply died while driving.
Now I replaced my opti with a new MSD distributor, I put a new MSD coil in and 8.5mm super conductor wires.
I´ve got the car completly done now. Everything is read "for take off".
But the MSD distributor has a different 4 pin connector than the harness or my car.
I have a 5 pin connector.
I found out that the connector changed from 92 to 93.
So the MSD would fit a 93.
I would need the wiring diagram of the car and the MSD unit.
If I have the color codes of the wires I could solder the old distributors connector to the MSD.
I hope someone can help.
Old Aug 23, 2010 | 05:05 PM
AustrianVette
No one??
Old Aug 23, 2010 | 07:20 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I know my Dynaspark had the same thing - IIRC the 5th wire is just a covering of foil.
The Dynaspark came with instructions on how to wire it in, maybe you can find the instructions on their website?
To MSD distributor wiring problems on 92 Vette
