There goes the tranny.
So what's the best thing to do. Rebuild, get a new one or swap 6 speed?
My day is f**kin ruined.
SOB!
SOB!
Just wait till you get the tranny rebuilt and the shift kit installed. You're gonna need duct tape to stop the corners of your mouth from pointing upward. Use your original trans for the rebuild not a swap. Keep it original. If you're going to do 3 & 4 why not do the others while you're at it. It's already open and no more labor or just very little to do the whole thing. Might want to check out HD clutches also.
Get a good rebuilder check with local vette mechanics or dealers.
Get a warranty both time(months) and Horsepower.
Mine when done 6 years ago had 1 year parts and labor and 600 HP guarantee.
SOB!
Except go with a higher stall. 2800rpm or so
I blew a sprag up in my tranny, having it rebuilt (the right way) and adding the stall ended up being 2 of the best things i've ever done to my car.
Transgo or B&M for shift kit?
All this over time will pay off at work.
How much does all of this usually run? I know tranny work can be a nightmare on the wallet.
Work Performed
CLUB MECHANIC (Labour @ $45.00/hr - $350.00)
Remove /Replace Turbo 700
Flush trans lines & cooler
Straighten X frame (convertible bracing)
TRANS SPECIALIST (Parts & Labour - $3500.00)
T700 Rebuild 4 speed Auto Trans - Extra components
Z pack clutchs, Brute sun gear shell, Heavy duty boost valve
Heavy duty servo, Drilled steel pistons, Stage 2 separator plate
Stage 2 shift kit , 2500 stall convertor ,12 Lts Dextron 3
Total $3850.00
PS: Pete K on the forum is the one to talk to.
Work Performed
Straighten X frame
Parts
Stage 2 shift kit , 2500 stall convertor ,12 Lts Dextron 3 $3500.00
Labour @ $45.00/hr $350.00
Total $3850.00
The $3500 was for parts and labour for the trans specialist to do the rebuild.
Hope this clarifies.
australian $3850= € 2740...things arent cheap here too
As we have a strong mining economy in Western Australia mechanics command big money. They are the richest people around. The guy with the best vette in our club (z06) has his own bobcat business for instance.
The last time I went to a dealer was for a tranny problem on my Ford SUV. They wanted $5000 just to remove the tranny from the vehicle to work out why the "check trans" light had come on on the dash! Instead I went to the local Chrysler dealer and traded it for a new turbo diesel jeep. Took the jeep for its first warranty service to just change the oil and the dealer charged $400!
So all in all the corvette is very economical compared with these new cars and hopefully hold their value better. A lot of fun and street cred too.
