I'm up for an oil change, am thinking royal purple... What grading? 10-30? Or 5-20? Or anything else? Recomendations? I live south of tx, where it's scorching hot outside... I'd appreciate it if someone helped me with the oil thAt can withstand the heat.. I think 5-20 becuz the haynes book n engine says that grade... Help please
I thought so, but kinda wanted to follow the book and engine cap. I was informed that a 1030 was a better choice for the heat, THANKS now I'm for sure buying a 1030
From: One day you're a Comet...the next day you're dust... Arkansas
10w-30 is what the manual calls for. I like 5w-30 synthetic blend in my 1989. Valvoline makes a good one for older or high millage cars that will condition your seals.
C4 of Year Winner (appearance mods) 2019
Heavier oil is usually a good thing for really hot climates. 10w-30, 10w-40, or even 20w-50 are all options. Synthetic is known for it's extra ability to fight the stress of high temps (like you describe).
Royal Purple HASN'T tested that well in wear tests. It's also over-priced IMO. Put at least one or two quarts of synthetic with dino. IOW, a blend or 100% synthetic should serve you well. I also think all the brands are acceptable. But, I'd let price and leaks influence my decision.
IOW, don't ignore lower-priced options than Royal Purple and don't be afraid to use heavier weights -- especially if you have oil leaks while running synthetics.
Note: Synthetics are more likely to leak in older cars because of their uniform molecular contruction. And, they aren't necessary for adequate protection.
Reason: Fixed error -- bold and underlined.
Originally Posted by L98RedVette
How does the 530 run in hot climate?
The same as 10w-30. The low end viscosity rating will give you a bit quicker pressure on a cold start. It's hot where I live we have had 49 days over 90* in a row and no nights under 70* since June 7th.
What manual is that? My 89 manual calls for 5w-30. Though I use 10w-30.
