AC replacment
Old Aug 25, 2010 | 12:45 PM
Crowhater's Avatar
Crowhater
Default AC replacment
I bought a new compressor, dryer and tube for my car and I will install these parts tonight then take it to get charged. Is there anything I should know or do? This is just a strait parts changing correct? Someone said something about putting oil on the o-ring seals?
Old Aug 25, 2010 | 02:10 PM
Al Borman's Avatar
Al Borman
Pretty straight forward R&R. Removing the old orifice tube will be the most difficult. They are wedged in the tube and don't usually pop out with a pair of needle nose pliers. Yes, oil the "O"rings prior to install. After removing old parts, cover line openeings with baggie and rubber band to keep out as much moisture as possable. Unplug/uncap the new parts just prior to install. Measure the amount of oil that drains from the dryer and compressor, as you want the AC shop to replenish the same amount. Ask them to run vacumm on system for at least 45minutes, an hour would be ideal.
You may end up needing to buy an orifice removal tool like this:
http://www.amazon.com/Interdynamics-.../dp/B002G1UNEO
PS... if your old compressor seized and/or you find a bunch of aluminum particles in the orifice tube mesh, I would recommend that you have the AC system flushed
Old Aug 26, 2010 | 07:59 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Stop by Harbor Freight Tools and see if they have an A/C orifice tube remover tool. Makes the job a lot easier. Runs about $15 bones or less.
To AC replacment
