I flunked the leak down test.
I suspected bad gas and thought it would go away if I put in better gas but it persisted so I started to poke around under the hood. I noticed that two of the plug wires were shorting out against the exhaust manifold and one was cracked and quite brittle so I changed them for a new set of Belden Max 8mm Blues from NAPA.
Back to smooth running but just for a few days. So I poked around some more and decided that I did not know the story on the injectors and three of them looked a little different from the rest so I bought a set of Bosche 3s from FIC and put them in. They look real nice with their yellow color but no change in performance, still running rough. Next I changed the fuel filter. Still rough.
So I took the car over to Corvette Mike’s house. He is a near neighbor who lives in the adjacent town and was kind enough to put his skills and his scanner to work. We also tested for fuel pressure which came in right on the money. But I guess I flunked the leak down test. It went from 39lbs to about 20 in less than 2 minutes.
How bad is that, what are the repercussions and does it have anything to do with my rough running?
I have numbers from the scan if it would help.
You could have fouled plugs because of the bad wires. Good Luck!
Check #7 for a leaking head gasket - all too common on this Year and a lot started dribbling with very low miles - like under the original warranty. That's often the cause of the driveability issue you've described and many owners don't discover it until it starts missing; backfiring etc. Unfortunately, by that time it's eroded a gully in the deck of the block, so to fix it correctly you're either machining the deck or putting in a short block.
The timing looked good, it was advancing, TPS was at .49. After it dropped to 20 psi on the fuel rail, it held for a short bit until I took the gauge off.
Whats the opinion on the 02 senser?
Mike
Hey Joe, you can borrow my fuel pressure gauge to follow SunCr's suggestion, Or bring it back over to my house and I will help you.
Where is this check valve?
I'm interested in your thoughts on the head gasket. Why would #7 be a particular problem? Wouldn't a head gasket problem should show itself with a compression test?
If you want to, you can buy the 12,000 lb. Rhino Ramp Extreme, but unless you've got like a full-sized SUV or pickup truck, there's no need.
And don't forget a dab of anti-seize compound for the new 02 sensor. Sometimes what they give you isn't enough to prevent the sensor threads from galling/corroding in the exhaust bung during its service life once its torqued in.
Stop by Harbor Freight Tools and get a crow's foot 02 sensor wrench. They run less than $10 and make the job a lot easier.
When you replaced the injectors did you also replace the FPR diaphram? If you pull the vacuum hose from the FPR is there fuel present? If so its leaking and needs replacement.
My theory is that the coolant restrictors on the rear of the intake gaskets allowed the crappy stuff to simply puddle on the rear of the heads and that's why #7 gets eaten up first. GM put those restrictors on the Vette (only - the F Body doesn't use them) to keep coolant at the rear of the heads longer to prevent hot spots; and in hindsight, it doesn't seem like it was such a hot idea. I found this site nearly 10 years ago because of the problem - many of us were discovering it with fairly low miles - mine was probably leaking by 25k. Poking around the net - like the defect section at www.nhtsa.gov, I turned up several lawsuits against GM about the issue - mostly from owners that found it shortly after the warranty lapsed. The complaints were quite old and have since been deleted. That seemingly led to the Service Bulletin which has been edited and now omits the phrase "to stop the high incidence of galvanic corrosion" along with some other language that makes the Bulletin appear quite benign.
As you may or may not know, GM no longer pumps coolant through the intake on all most everything they make. Some use composites too, though early examples, particularly on the 6's cracked and caused other problems. And some - aluminum and composite intakes - started sucking oil taking what GM called a "gasket set" from normal heating/cooling cycles. I haven't a clue as to why they can't or couldn't get it right; some experts blame it on the elimination of asbestos in modern gasket materials. The elimination of dissimilar metals - more aluminum blocks with aluminum heads has alleviated most if not all of the woes.
Compression testing doesn't always turn up the problem until it's obvious - new coolant that looks like crap within 6 months, plugged up heater cores, radiators, rust on the plug threads or an electrode that looks different from all the others, and/or an occassional Code 44 - super lean mix, are things that can clue you in.
As to your scan, if it's rich, it's more than likely dumping fuel from a leaking injector. Coolant, even in small amounts, leans it out - not that yours isn't; the leaking injector could be masking the problem. In any event, I wouldn't own another L98 ('88 through '90) without investigating this issue. A lot have been fixed, but they keep breaking because they weren't fixed correctly; ie, the deck is no longer square and they're still sucking coolant pass the new head gasket on the downstroke and pumping exhaust into the coolant on the up.
Check valve is part of the Pump Assembly and as far as I know, not servicable; ie, you gotta replace the whole pump.
There are flexible hoses just below the Tensioner which can be clamped off with some Vise Grips, but wrap a shop towel around the hoses.
Hopefully its not a blown head gasket. Did you change the fuel filter with the rest of the tune-up? Check the vacuum line to the fuel pressure regulator for fuel.
When I had my fuel pressure problem I called Jon at FIC for his take on it. He walked me through some procedures and gave me specs and suggestions. He was instrumental in my diagnosis, along with the guys here on the forum. Being you got your Bosch III's from FIC, give him a call.
Jake
Once you have eliminated that flimsy troublemaker, then redo the fuel pressure leakdown test.
THe pulsator was a great idea, but a bad execution on GM's part.
Take that thing and throw it as far as you can.
The biggest problem with it is it is over 20 years old, and the silicone rubber has stretched over time, and there is no way to clamp it to the line to eliminate leaks.
The problem that I find with 'Ol #7 is it runs lean because of the intake configuration. GM added that little hot water tube on the L98 to keep water flowing in that area, eliminating hot spots. Don't know if it works or not, but i am not going to eliminate that hose , either.
as far as the car running badly,
you need to determine if it's electrical or fuel . IT could also be a vacuum leak as well, or a bad sensor (O2, temp, ignition control module, esc, etc.)or FPR, or anything. Just be persistent, and you will overcome.
Thank you for that detailed post. I knew about the head gasket issue because I went thru it my self. I had no clue to what was really going on. This forum is so awesome when we can all learn.
Thanks again SunCr.
I usually always learn something from all your posts Mike
I also changed the O2 sensor as well as cleaned the distributor cap and rotor with a little light sanding. While I had all those wires dangling I rerouted the spark plug wires and added a set of separators to them to keep them from touching places they should stay away from. I recommend to anyone having rough running or idling or generally not running as smooth as you would like to make sure your spark plug wires are properly positioned and separated with the use of retainers. If you do not have them, get them.
My C4 coupe is now running like a top and I am very happy. I plan to drive it like this for a few days to see if this effort holds up before I pester Corvette Mike for a retest of the leak down issue.
I also thank all the helpful people for their advice and I believe I will know what to try next if this problem comes back. But for now I'm back in the saddle again!
