codes
Old Aug 25, 2010 | 06:46 PM
jim dodd's Avatar
jim dodd
Default codes
code says catalst system eff. below threshold bank1 what does this mean and can i drive it without hurting the motor if i need to get a new cat, wheres a good place to get one or does anyone have agood used one drivers side is what ive been told 96 lt1 auto.
Old Aug 26, 2010 | 12:03 AM
shadowman1's Avatar
shadowman1
That would be a code P0420. That means your left side cat is going bad. You can get a cheap replacement but remember you get what you pay for. A factory cat will have more precious metal in it hence the higher cost. Always check for any vacuum or exhaust leaks and proper switching of the O2 sensors before replacing the cat.
