Oil Filter for '95 LT1
Old Aug 26, 2010 | 07:07 AM
hogsnvettes's Avatar
hogsnvettes
Default Oil Filter for '95 LT1
Tomorrow morning I pick up my first vette and time is moving at a snails pace. I'm trying to pass the time by researching all the options I'll have for keeping it in top condition and maybe making an improvement here and there. One itme that is top on my list is doing an oil change with Amsoil's 5w30 and filter. I've read a couple posts discussing a larger filter to increase the amount of oil in the system. Sounds like a really good idea. What filter is recommended when doing this? I assume the larger filter would increase capacity by maybe a half quart.
Old Aug 26, 2010 | 07:14 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Not to hijack, but is the AC/Delco PF-52 filter still available? I've heard it's been replaced. If so, what model replaced it? That's the one I've used for the last 10 years since I've had my LT1.
Old Aug 26, 2010 | 07:18 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
I run the Mobil 1 extended performance filter (#201) which is a longer filter. Not sure if it is a full 1/2 quart more but almost.
Rick
Old Aug 26, 2010 | 07:22 AM
onedef92's Avatar
onedef92
Rick
I know that with the stock Delco filter, the oil/filter capacity is 5 quarts on the money. That's why I like the five-quart, convenience-sized jugs of M1. Makes oil changes that much easier since they're pre-measured.
Old Aug 26, 2010 | 07:28 AM
PDQUIK95's Avatar
PDQUIK95
I'm also running a Canton 7qt.road race pan so actual volume increase from longer filter is unknown. 7 qts puts my level at about a 1/2 qt low on a stock dipstick.
Old Aug 26, 2010 | 07:30 AM
onedef92's Avatar
onedef92
Are you planning on getting a longer dipstick to compensate?
Old Aug 26, 2010 | 07:34 AM
PDQUIK95's Avatar
PDQUIK95
No. The stock stick is fine. 1/2 qt. is just the new full mark.
To Oil Filter for '95 LT1
