[Headers]: L98 guys with headers.....
Old Mar 28, 2002 | 03:45 PM
scorp508's Avatar
scorp508
Default [Headers]: L98 guys with headers.....
Do you have any pictures of the driver's side that shows the headers, and the alternator?
I need to figure out of the rear brace for the alternator is going to fit or not. If it doesn't I might be screwed. The last time I didn't install that brace (when installing the AIR pump eliminator) the engine torqued the alternator over and cracked the housing. :(
Thanks!
Old Mar 28, 2002 | 04:27 PM
scorp508's Avatar
scorp508
Default Re: [Headers]: L98 guys with headers..... (scorp508)
Ok since nobody wants to reply. :) How about a 2nd question for you. Anybody dyno before/after on a relatively stock L98 and got some #s?
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Hey Scorp,
Would Like to know this as well...maybe JD has a pic with his motor in that area since hes got the eliminator as well.
Also, with my Kit,I did use the rear bracket with the stock manifold but the TOP bracket that used to bolt the smog pump to the intake manifold wouldnt reach anymore and I asked the BPP guys if they had a bracket to mount the back f the pulley to the intake for more rigidity but they didnt make one.
So IF anything,maybe you can make your own bracket to support the back of the pulley and bolt to the intake which MIGHT keep the system in alignment better under load if the rear bracket cant be used anymore w/headers...what do you think..doable or no?(even though I know the alternator is further down)
I still might make one for up there anyways.Those two long bars may warp without the additional support over time.
Old Mar 28, 2002 | 04:31 PM
scorp508's Avatar
scorp508
Yeah that part missing is why I think makes the biggest difference. I'll have to look into fabricating a new on. The AIR pump bracket goes "over" the alternator, and supports it from the front/back at the same time in a way. The eliminator only bolts onto the front side of the alternator. I think the original bracket helps keep the alternator from torquing a bit in this matter also.
I've already messed up 2 alternators because of this eliminator, I'd like to try and save the rest. :)
Old Mar 28, 2002 | 04:33 PM
dgoodhue's Avatar
dgoodhue
I wil get some picture tonight if you would like, I didn't install mine the first time they were put in. I have seen some Dyno's of headers gain ~15rhwp and 20lbs of torque, but you never know if the car had partially clogged precats or not. The Headers made a huge difference in my 86 but my passsenger precat was already rattling.
[Modified by dgoodhue, 3:35 PM 3/28/2002]
Old Mar 28, 2002 | 04:35 PM
scorp508's Avatar
scorp508
Thanks Dave!
Old Mar 28, 2002 | 04:38 PM
-=Jeff=-'s Avatar
-=Jeff=-
I can take some Pictures tomorrow as well
Old Mar 28, 2002 | 04:41 PM
dgoodhue's Avatar
dgoodhue
Default Re: (scorp508)
I just remembered that my Wife has our Digital Camera at work (she work a half day today), so I can't get a picture tonight. My car has an air pump, but the TPIS big mouth intake didn't line up properly with the air pump bracket, so I had to leave it off. I will atleast check it out to see what my car has for brackets.
Old Mar 28, 2002 | 04:42 PM
Aggravated4life
I just looked at the motor again...hmmm..doesnt look like it will change much by installing a bracket on top as seeing how far down the alternator is.
Sturdier up there,yes but stopping alternator swinging,prob. wont make much difference.Cant hurt though for up there.
Ill check this thread for some pics later and see whats "left" as far as room goes and if anything can be used back there.
Old Mar 28, 2002 | 04:43 PM
J Z06's Avatar
J Z06
Default Re: (Bill's86Coupe)
ask and you shall receive. don't mind the crappy coating.
Old Mar 28, 2002 | 04:45 PM
Nathan Plemons's Avatar
Nathan Plemons
I know mine's an LT1, but I just thought I would add my $.02 anyway. Free post and all. :)
None of my brackets are installed that go from the alternator or A/C compressor back to the block or mainfolds. One of them would fit, the others won't. So far I haven't found any trouble running without them. It's a good thing because it would be impossible to install them. I've got some pictures on my web page.
http://12.222.168.65/htmls/corvette.html
Old Mar 28, 2002 | 04:53 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Re: (JD 90 383)
Mine looks like JD's. If you HAD to, you can gut/grind/weld/fabricate just about anything, so I'm sure if it was super important, we could make a custom stud for that back bracket and modify the bracket to clear the tube. If you to Doc's tomorrow night,AND if my car is done, I'll show you.
Old Mar 28, 2002 | 04:58 PM
Mojo's Avatar
Mojo
Mine fit fine.
Old Mar 28, 2002 | 04:59 PM
scorp508's Avatar
scorp508
Default Re: [Headers]: L98 guys with headers..... (Mojo)
Mine fit fine.
Ohhh I like that pic better. ;)
Old Mar 28, 2002 | 05:20 PM
Mojo's Avatar
Mojo
Thanks! :) The 2149's come with a spacer for the bracket.
Old Mar 28, 2002 | 05:28 PM
codyusa's Avatar
codyusa
CI 5-6-7-8-9-10 Veteran
Scorp- you have mail.
Old Mar 28, 2002 | 05:34 PM
hc's Avatar
hc
Chris,
Your engine looks great :)
But I'm not sure if it answers Scorp's question, because you still have the air pump attached. With the air pump eliminator bracket the alternator moves down and out further - - (I've got an air pump eliminator bracket too, and I'm also looking at getting headers) - - so, I'm also concerned on whether or not the rear bracket will work and with which header (I was looking at either the TPIS or LPE ones). :confused:
To [Headers]: L98 guys with headers.....
Old Mar 28, 2002 | 05:53 PM
jburnett's Avatar
jburnett
I'm running LPE headers on my 90 and I'm not using the secondary alternator bracket on it. Now, my car has a different alternator than the earlier C4's, so I scoped out my wife's 85 with the Hooker headers... I have a bad memory and couldn't remember whether I used the bracket or not...I didn't. And we haven't had any probs. I'm also using the 2151 headers instead of the 2149's which are exactly the same except there are no smog fittings and the O2 bung is in the collector instead of #7 exhaust runner like on the 2149's.
-Jeb Burnett
Old Mar 28, 2002 | 06:23 PM
Aggravated4life
Default Re: [Headers]: L98 guys with headers..... (jburnett)
Great pictures guys,and JD thanks for the fast reply.Looks doable either way you go wether make one or adapt the stock piece to it..Thats good to know for future mods.
Old Mar 28, 2002 | 06:44 PM
J Z06's Avatar
J Z06
Default Re: [Headers]: L98 guys with headers..... (Bill's86Coupe)
Not a problem.
Glad to have helped.
