Hypertech Chip
Old Aug 30, 2010 | 02:50 PM
C-FOUR KID's Avatar
C-FOUR KID
4th Gear
Default Hypertech Chip
Ok im new to the corvette scene..Has anyone ever purchased this Chip buy HYPERTECH, and possibly seen positve results..an if soo how hard is it to install.. Thanks
Old Aug 30, 2010 | 03:26 PM
ch@0s's Avatar
ch@0s
It's snake oil don't buy it.
Old Aug 30, 2010 | 04:06 PM
hamrhed42's Avatar
hamrhed42
i have that that chip cost me 3 mpg and smoothed out the idle ond off idle response, besides that junk. Google pcmforless they are cheaper and will burn to the mods you have. Very easy to install
Old Aug 30, 2010 | 04:37 PM
markKlein's Avatar
markKlein
Unless you have made major modifications a new chip will not do anything for you.
Old Aug 30, 2010 | 05:03 PM
WW7's Avatar
WW7
Its Junk.....
You can get a custom tune for less money....WW
Old Sep 1, 2010 | 07:07 PM
Big8Dee's Avatar
Big8Dee
What makes it worthless?
Old Sep 1, 2010 | 07:49 PM
TA's Avatar
TA
The same thing that makes air foils and TB spacers worthless...................they do little (if anything) to improve performance
Old Sep 1, 2010 | 07:50 PM
John A. Marker's Avatar
John A. Marker
Okay....true story...before I found out about the Forum I leaped at the chance to add 50 HP to my stock 85. So I bought the hypertech chip and the 160 thermostat. It was a easy installation. That is the best I can say for the chip.
Over the next two years I was having problems with PING. It happened some times on level ground and some times on the up hill grade. It was not consistent. I changed the knock sensor. No change. I changed gas stations....went through most of the well know brands. I added octane boost. No change. Complete tune up. No change. I finally started to play with the distributor. I would change the setting and drive it. If the engine PINGED, I would change the setting again. I did this until 90% of the time I did not get the dreaded PING!
I talked to Tom Wong up in Vancouver Washington and arranged for a dyno tune on my mostly stock car. He did a base line scan and discovered that the Hypertech chip was advancing the distributor setting to 43 degrees as you accelerated and at the same time was REMOVING fuel! So it all boiled down to the chip was creating the PING by advancing the distributor and leaning the fuel mix. He burned me a custom chip and I never had a problem with PING after that. And the Hypertech chip DID NOT add 50 HP! Tom dialed in the car to get the most HP out of my mostly stock car. The best part was that going up to see him I averaged 26.4 MPG. After his tune....I averaged 27.2 going back.
Don't waste you money on the chip, find someone that can do a custom tune for your car.
Old Sep 1, 2010 | 08:59 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I have 2 computers for my 92. One is the computer that came with the car and had the Hypertech installed.
THE ONLY DIFFERENCE BETWEEN THE TWO COMPUTERS IS WHEN THE FANS COME ON!
Old Sep 1, 2010 | 11:59 PM
C-FOUR KID's Avatar
C-FOUR KID
4th Gear
Hey sounds good guys. Thanks for the feed back..Whats the deal with this "pcmforless" sounds pretty shady to me... And how does SLP intake runners perform on these L98s ..
To Hypertech Chip
