Dic - 1990 c4
Old Aug 31, 2010 | 05:39 PM
Mixednuts's Avatar
Mixednuts
Default Dic - 1990 c4
It there a write up on how to dismantle the console / radio area and up to the DIC so I can check the bulbs?
-J
Old Sep 1, 2010 | 09:51 AM
sailorsteve's Avatar
sailorsteve
The DIC assembly includes the switchpad to the left. To remove it, you have to remove the console trim and the a/c outlet above it. Then you can remove the trim panel that surrounds the DIC. To remove the shift ****, pry the button out and you will see the retainer inside, a snap ring for automatics and a wedge shaped pin for 6-speeds that is held by a setscrew just under the **** on the rear side of the lever.
Old Sep 1, 2010 | 12:36 PM
Mixednuts's Avatar
Mixednuts
Thanks Sailorsteve -- Appreciate your time. This helps a lot.
-J
To Dic - 1990 c4
