Not sure if this is the right place in forum for this but here we go and hope this might help some others . Our 1990 C4 had been stumblling and running rough before it finally would not run very well at all . The engine was a L98 and still had the stock injectors from the factory . After reading the forums and checking for codes (there were none set) . I checked the wiring and firing with a set of noid lights which showed that the injector pulses were still working . I followed the advice of a lot of people here on the forum and called Joh Banner @ Fuel Injector Connection and ordered a set of the Bosch 3 injectors . To make a long story short . PROBLEM FIXED Thanks Jon and thanks to everyone at corvette forum .
Not sure if this is the right place in forum for this but here we go and hope this might help some others . .
I wish more members were like you and would post "solutions" to their car issues, instead of just posting the problems and then never reporting back how/if they resolved their issues !!
Post likes yours are very valuable, especially when the problem is ellusive, ie no error codes, noid light shows working injectors.....and BLAM.... a set of new injectors solve the problem. I suspect the the problem is that Noid lights wont tell you if you have a leaky injector or an injector that has poor atomization spary due to gummed up or worn out pintle.
Should be a mandate on CF that folks report the............."Final Solution" !!!
I also bought injectors from John last week ( 24# Bosh III ) and it fixed my car right up. He said that the ethonal in todays fuel ate up the inside of my old injectors. $300 dollars for injectors and the intake gasket set.
PS: my timming was also a little retarded so when we set it back to factory the car really came to life.
