need a little code help
Old Mar 28, 2002 | 09:05 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default need a little code help
I am at work, so don't have my service manual, so who can tell me
what a code 32 is?
Old Mar 28, 2002 | 09:08 PM
BobMachus's Avatar
BobMachus
Default Re: need a little code help (No Ordinary 91)
Exhaust Gas recirculation circuit
Check the vacuum source and all vacuum lines. Check the system electrical connectors the ECM and EGR valve. Replace the EGR valve or ECM as necessary (see Section 5).*
*Component replacement may not cure th problem in all cases. For this reason, you may want to seek professional advice before purchasing replacement parts.
[Modified by BobMachus, 6:12 PM 3/28/2002]
Old Mar 28, 2002 | 09:14 PM
No Ordinary 91
Default Re: need a little code help (BobMachus)
Ah man, I thought that it was the O2 sensor again, guess I'll have to go out and check the EGR again, I had one of the lines come off a while back
To need a little code help
