'93 owners - wondering if you have a 700R4 (4L60) or a 4L60E?
Old Mar 28, 2002 | 10:16 PM
cprgmr's Avatar
cprgmr
Default '93 owners - wondering if you have a 700R4 (4L60) or a 4L60E?
Here's how to tell...
Pic from '95 w/4L60E (thanks 95_C4_convertible)
Pic 1 from '93 w/700R4 (4L60)
Pic 2 from '93 w/700R4 (4L60)
Old Mar 29, 2002 | 06:05 AM
93 ragtop's Avatar
93 ragtop
Default Re: '93 owners - wondering if you have a 700R4 (4L60) or a 4L60E? (cprgmr)
Cprgmr,
Good pictures. According to David F. if you have a 93 vette auto, you got a 4L60 from the factory. The E version did not come out in the vettes until 94. IMO the confusion comes in as people are thinking 700R4 or 4L60E. They dont realize that somewhere along the line GM started calling the 700R4 the 4L60. The factory service manual refers to the 4L60 only, no 700r4 and no E version. The pictures you posted are great and of course I believe the key difference that could be picked up from them is the 93 has the TV cable going down to the transmission. The 94 and up (E version) does not use a TV cable. By the way, I sure wish my engine was that clean!!
Old Mar 29, 2002 | 10:31 PM
Alex D's Avatar
Alex D
Default Re: '93 owners - wondering if you have a 700R4 (Red 86 4+3)
The name change came as GM decided to standardize the designations for the automatics. The TH700R4 is the same as the 4L60.
4(four speed)L(longitudinal installation)60(max. torque capacity)E(electronic version)
for eample the FWD GTP tranny is a 4(four speed)T(transaxle installation)65(torque rating)E(electronic)
The old Th400 became the 4L80E. Cadillac Northstars have aspecially developed transaxle only found in those cars (high rpm capacity, Northstars shift at 6,500rpm, and different shift algorythms). They are called 4T80E
[Modified by Alex D, 8:33 PM 3/29/2002]
Old Mar 30, 2002 | 05:50 AM
93 ragtop's Avatar
93 ragtop
Default Re: '93 owners - wondering if you have a 700R4 (Alex D)
So if the 60 stands for torque rating, what does this translate to in ft. lbs.?
[Modified by Red 86 4+3, 3:52 AM 3/30/2002]
Old Mar 30, 2002 | 10:13 AM
cprgmr's Avatar
cprgmr
Cprgmr,
Red 86 4+3 - This is exactly what I was trying to illustrate (with the TV cable), but I think you did a great job of explaining the pics! :) BTW - thanks for the compliment on the engine bay, but it still needs a lot of work! :D Great info guys!
Old Mar 30, 2002 | 10:51 AM
Alex D's Avatar
Alex D
Default Re: '93 owners - wondering if you have a 700R4 (cprgmr)
Red, the 60 is the torque capacity rating, but it does not have a direct realtionship to the max. torque value the tranny is designed for. I once thought the 60 stood for 600 ft./lbs. but I do not believe that is true.
Anyone interested in detail on all GM automatic transmisisons will find a good resource here: http://www.gm.com/automotive/gmpower...ions/index.htm
Old Mar 30, 2002 | 02:07 PM
Goody's Avatar
Goody
All should note that no '93 came with a 4L60E because a '93 does not have a PCM (power train control module) it has an ECM (engine control module). The PCM controls the Torque Converter lockup function. :seeya
To '93 owners - wondering if you have a 700R4 (4L60) or a 4L60E?
