Rear brake lockup?
Old Sep 2, 2010 | 08:34 PM
Tom 35th anniversary's Avatar
Default Rear brake lockup?
Ok, I am not the most informed on brakes and their problems. What would cause my right rear brakes to lock up when I lean hard on the pedal? I know they are supposed to lock up if I hit em hard enough , but the right rear is the only one locking up and it makes the car shimmy sideways something fierce!!!! Its an accident waiting to happen if you know what I mean. Any help will be greatly appreciated!!!!
Old Sep 2, 2010 | 08:56 PM
ex-x-fire's Avatar
ex-x-fire
Inspect the brakes for contamination, any brake fluid, grease, ect on the pads will make them grabby.
Old Sep 3, 2010 | 11:21 AM
sailorsteve's Avatar
sailorsteve
Jack it up and see if the wheel is dragging. There might be crud or corrosion on the caliper or pads keeping them from releasing fully.
Old Sep 3, 2010 | 05:52 PM
desertmike1's Avatar
desertmike1
is your car equipped with ABS, if so...you should not have any lock up.
To Rear brake lockup?
