need help dont know whats wrong
Old Sep 3, 2010 | 03:19 PM
gagnard1's Avatar
gagnard1
Default need help dont know whats wrong
Ok i have a 1991 c4 corvette and its running pretty bad the sys light comes on and there this clicking every once in a while where the lcd screen is. it and it trys to die when i stop at a red lights and and stuff i think its the ecm but not sure what it is if any body knows plz answer
Old Sep 3, 2010 | 03:23 PM
gagnard1's Avatar
gagnard1
ps i has a slr chip that grounded it self out and went bad dont know if this helps
Old Sep 3, 2010 | 03:34 PM
jnealg's Avatar
jnealg
what codes is it throwing?
Old Sep 3, 2010 | 04:42 PM
gagnard1's Avatar
gagnard1
it had a code 45 Rich Exhaust Present i know thats the 02 sensor could that possibly be it that is the only code it is showing
Old Sep 3, 2010 | 04:59 PM
joe3906's Avatar
joe3906
My 91 had similar symptoms. It turned out to be the ignition control module; you might want to check that. Good luck.
Old Sep 3, 2010 | 05:04 PM
gagnard1's Avatar
gagnard1
ok ill check that out.thankz
Old Sep 3, 2010 | 08:14 PM
90WhiteLightning's Avatar
90WhiteLightning
I have a 90 and it was the same thing..the ECM was bad
Old Oct 14, 2010 | 10:06 AM
gagnard1's Avatar
gagnard1
k thanks for all the help it had a bad ecm all 8 injectors where bad so we replaced them and we rebuilt the distributor and know it runs as smooth as could be
Old Nov 15, 2010 | 09:17 AM
gagnard1's Avatar
gagnard1
found out what was wrong all 8 injectors and vaccum leaks so if u are having the same problem check those things out and the ecm was bad
To need help dont know whats wrong
