SLP Intake Runners?
Old Oct 18, 2010 | 08:08 PM
  #41
Calderone's Avatar
Calderone
i love the SLP's looks !!!
Old Oct 19, 2010 | 02:21 AM
  #42
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by Calderone
i remember a thread that somebody lost power with too much siamesing
but it was on a Super Ram,not sure if its the same effect on the LTR setups
It could. As with a cylinder head, the shape of the porting job could have adverse affects. Some people's porting jobs looks like crap. It needs to look smooth (like the pics in this thread). Also, preferably, you'd want a slight taper to a smaller diameter at the base. (This helps speed flow.)
Also, as Slick pointed out in this thread, the stock/aftermarket TPI bases have a limitation in the way their final turn (into the head) pinches air flow. If you want maximum HP, a stock-style TPI intake isn't the right one for you. It's for torque junkies.
Old Oct 19, 2010 | 10:47 AM
  #43
GKK's Avatar
GKK
The SLP runners look Very Tough and Aggressive!
Old Oct 19, 2010 | 12:34 PM
  #44
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Originally Posted by Big8Dee
after failing on my first mid america purchase (hyperjunk chip, air foil, tb spacers) i was wondering if anyone has found this mod useful?
It appears to me that the OP is looking for an "easy bolt-on" that reaps some tangible gains. Look that the other parts he's tried above. I doubt that lower's, extensive porting, etc are in this posters near future.
In light of that, the answer to the original question "[is] this mod useful?"
NO. Not on a stock or stockish engine that is going to stay stockish. For the price of the SLP runners ($300+) there are more effective things that can be done, IMO.
Old Oct 19, 2010 | 12:35 PM
  #45
flatbush862's Avatar
flatbush862
Default SLPs
I have done the mods. (1990 , A4, 3.07 axle) in the attached photos and they work really well in the mid to high RPM ranges. There is a definite improvement over the stock setup.
Along with the SLPs, going with the K&N filter, dialed up fuel pressure, cat back exhaust ( I have Magnaflow), tossed frisbee, TB bypass and the PCM custom chip, the car runs great.
You will not see dramtic improvements without a heads cam package however. I understand that this is bit of a crap shoot with aftermarket parts when it comes to emissions. I don't have OBD II and it would be difficult to predict the outcome on emissions. This is a problem where I live in New York. If anyone knows different, or has gone with a heads cam package on an L98 that has not had an emissions issue, I'd love to hear from you.
Flatbush 862
Old Oct 20, 2010 | 10:26 PM
  #46
grantar2's Avatar
grantar2
[QUOTE=flatbush862;1575667030]I have done the mods. (1990 , A4, 3.07 axle) in the attached photos and they work really well in the mid to high RPM ranges. There is a definite improvement over the stock setup.
What is a tossed frisbee?
Old Oct 20, 2010 | 10:55 PM
  #47
GREGGPENN's Avatar
GREGGPENN
There's a big round piece of metal bolted to the waterpump. Some people remove it for rotational weight savings. Most find it a satisfactory mod. A few select people notice a vibration when the A/C is turned on. (That add'l rotational mass was designed to stabilize the engagement of the A/C clutch.)
No doubt a seach on the word frisbee would have revealed this tidbit.
Old Apr 30, 2011 | 10:15 PM
  #48
Big8Dee's Avatar
Big8Dee
can iexpect some results on the butt dyno with a tpis bigmouth base coupled with ported and Siamesed stock runners, and ported stock plenum?
Old Apr 30, 2011 | 10:18 PM
  #49
Big8Dee's Avatar
Big8Dee
and is removing the screens inside the MAF provide gains?
Old Apr 30, 2011 | 10:25 PM
  #50
cv67's Avatar
cv67
St. Jude Donor '05
Whole intake system yes youll feel it. Wont be a HUGE difference but you will notice it.
Descreening your MAF is a complete waste of time and you risk damaging it found that out the hard way.In short fried the head gaskets causing it to run lean intermittently. The whole time it seemed to "run fine" as you hear so many say (when the subject of tuning comes up)
Well it wasnt fine.
Intake will not affect emissions other than the visual part of it.
it just moves air.
Old Apr 30, 2011 | 10:55 PM
  #51
JackDidley's Avatar
JackDidley
Originally Posted by Pete K
Intake modifications should be addressed using a systems approach. If you are looking to bolt those runners on, and pick up seat of the pants performance, save your money. Gains may be possible on the dragstrip or dyno, but your butt dyno will feel nothing.
You may get .2 at the dragstrip. Wont even feel it on the street.
Old Apr 30, 2011 | 11:57 PM
  #52
GREGGPENN's Avatar
GREGGPENN
Mega-SLP/Bigmouth combo should feel similar to installing a superram. Not as much top-end but it'll run up higher. Some people may not notice it pulls longer (vs harder). Should get SOME of each though.
Unless shortblock has been modded, don't descreen your MAF. It won't help enough to notice. Bigger chance it could hurt -- and require retuning. The intake swap should be good to go.
Old May 2, 2011 | 03:14 PM
  #53
Big8Dee's Avatar
Big8Dee
[QUOTE=Tom400CFI;1575667010]It appears to me that the OP is looking for an "easy bolt-on" that reaps some tangible gains. Look that the other parts he's tried above. I doubt that lower's, extensive porting, etc are in this posters near future.
with my TPIS base in the mail, and my plenum and runners in the process of being removed to be sent out and ported, I am proud to denounce your future prediction, although I appreciate your input.
Old Jul 28, 2011 | 07:26 PM
  #54
Big8Dee's Avatar
Big8Dee
Hey guys. My updated build log kinda got lost in my "TPIS BIGMOUTH COOLANT...HELP" thread. thanks for all the input guys. this thread really gave me an idea on how i can build a stronger tpi engine
Old Jul 28, 2011 | 10:11 PM
  #55
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
So what is your point?
If you toss enough time, money and resource at something it will produce positive results?
I think anyone would agree with that, if done properly.
A ported plenum, ported base, and aftermarket runners are combined with a proper tune, you could spend anywhere for $500-$2000 bucks. Much more if writing a check to a shop for all of the work.
TPI has worked, and will continue to work for years. That is a fact.
It is normally more cost effective to swap out the manifold, using a full system approach. This assumes the ultimate goal is big power gains over stock. That is the subject for debate.
I have done it all. The most money I wasted to NOT achieve strong gains was to monkey around with the stock type, long length factory (or replacement) runners.
^^^Listen to this guy, he knows his stuff^^^
