SLP Intake Runners?
Old Sep 3, 2010 | 06:14 PM
Big8Dee's Avatar
Big8Dee
Default SLP Intake Runners?
after failing on my first mid america purchase (hyperjunk chip, air foil, tb spacers) i was wondering if anyone has found this mod useful? thanks for the replies, anything helps! =)
Old Sep 3, 2010 | 06:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
They do best if they are heavily ported and some siamesing done;a similar base with work done will complement it. Check Ebay
Anything is better than stock though.If you were looking to bolt them on and feel a huge power increase you might be let down.
Old Sep 3, 2010 | 07:17 PM
ch@0s's Avatar
ch@0s
Do this to your intake and runners and you will be in good shape.
http://www.gmtips.com/3rd-degree/dox...-port/port.htm
Old Sep 4, 2010 | 08:48 AM
WW7's Avatar
WW7
If your engine is stock, don't bother changing your intake, you can however port what you have on there now, it doesn't cost anything to port it except your time and the price of gaskets. You won't feel much difference unless your motor is upgraded , with stock motors (in my opinion) its not worth the money...WW
Old Sep 4, 2010 | 10:31 AM
89 Vett's Avatar
89 Vett
I only partially agree with WW7.
The most restrictive elements on the L98 are the intake components and exhaust. Opening up the intake/plenum/runners and tb coupled with better exhaust will produce significant gains for relatively little money. A retune of your chip is cheap and these changes play well with other mods later if you choose to make them.
Old Sep 4, 2010 | 11:38 AM
ch@0s's Avatar
ch@0s
That the place to start intake and exhaust. If I wanted the most out of my stock L98 I would do an intake exhaust 1.6 RR and a tune.
Old Sep 5, 2010 | 07:18 AM
rpoL98's Avatar
rpoL98
I suspect 1.6RR would also require a valve spring swap.
IMHO, not sure if a larger TB is needed if you've still got the stock cam, even with intake, runners, plenum, LT headers.
I'm going through this right now myself.
91 L98, Edelbrock TPI base, SLP runners, ported plenum, and long-tube headers. 1.5RR (non-SA) with new guideplates & pushrods. I hogged out the SLP runners at the top where it mates with the plenum, and port-matched the lower side of the SLP runners to the Edelbrock TPI base. stock 113 heads.
I might do the 1.6RR (w/ springs) later on. right now just trying to get the car back on the road before it starts becoming a permanent fixture (garage queen).
Old Sep 5, 2010 | 08:53 AM
Pete K's Avatar
Pete K
Intake modifications should be addressed using a systems approach. If you are looking to bolt those runners on, and pick up seat of the pants performance, save your money. Gains may be possible on the dragstrip or dyno, but your butt dyno will feel nothing.
Old Sep 5, 2010 | 12:53 PM
WW7's Avatar
WW7
The OP didn't say he was going to replace his Manifold, or have his plenum reworked, or install headers. He ask if SLP runners were a useful modification. If installing the runners is all that he had in mind then my answer is correct. Porting and port matching the stock intake would give more in the way of performance then just adding SLP runners. I can tell you from the purchase I just made a few months ago , Plenum porting, high flow runners, Edelbrock intake and Hooker ceramic headers will run you $1,700 ... If I knew what I know now I would have done like Pete K told me before I put my intake together and just purchased a Super Ram or maybe a Mini Ram intake and been better off...Live and learn......WW
Old Sep 5, 2010 | 01:07 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Some good advice here:
http://temp.corvetteforum.net/c4/vader86/
Old Sep 5, 2010 | 02:30 PM
steven mack's Avatar
steven mack
Default Tpi
If tpi can't be made to work then what do you call the intake on top of the new Ls series of GM V8's?It sure isn't a super ram or a mini ram.The guys over on the Third Gen forum have been making great numbers with TPI intake systems.They use a ported stock plenum siamesed SLP runners and a ported Edlebrock intake,plus a proper tune.
Old Sep 5, 2010 | 03:04 PM
Pete K's Avatar
Pete K
So what is your point?
If you toss enough time, money and resource at something it will produce positive results?
I think anyone would agree with that, if done properly.
A ported plenum, ported base, and aftermarket runners are combined with a proper tune, you could spend anywhere for $500-$2000 bucks. Much more if writing a check to a shop for all of the work.
TPI has worked, and will continue to work for years. That is a fact.
It is normally more cost effective to swap out the manifold, using a full system approach. This assumes the ultimate goal is big power gains over stock. That is the subject for debate.
I have done it all. The most money I wasted to NOT achieve strong gains was to monkey around with the stock type, long length factory (or replacement) runners.
Old Sep 5, 2010 | 03:26 PM
steven mack
Default Tpi
I am sure most of us who have been working on Tpi long enough have seen the article from Comp Cams on the different intakes for our cars.If you go over the article you will see that the trade off is usually torque or horse power.A Mini ram new is not cheap.They don't make Super Rams any more so whats your point.So you missed something in your TPI build that you did not reach your goals for your motor.
Old Sep 5, 2010 | 03:40 PM
Pete K's Avatar
Pete K
I don't read articles. I build stuff and run it. I will look for it (Comp's article) so I can better educate myself. Send the link if you have it.
Old Sep 5, 2010 | 04:05 PM
steven mack
Default Tpi
The Results from the article can be found at Third Gen.ORG.Look in the messages forum under TPI .Also check out the article in search of a better flowing TPI.They have to stick with Tpi because of Cali smog laws.I agree with your statement that it has to be a complete systems approach.Just bolting on one thing will not make a big difference.From the people I know who build things for fuel injection.The most efficient is a single plane setup.
Old Sep 5, 2010 | 06:51 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
http://www.compcams.com/Community/Ar...?ID=1737510521
Old Sep 5, 2010 | 07:44 PM
Calderone's Avatar
Calderone
Thats a very good read,i always read it from time to time,very good article
To SLP Intake Runners?
Old Sep 5, 2010 | 11:46 PM
ch@0s's Avatar
ch@0s
No, the springs will be fine with 1.6 RR
Old Sep 6, 2010 | 11:02 PM
GREGGPENN's Avatar
GREGGPENN
Link went missing today. Maybe article is finally pulled from website?
Old Sep 6, 2010 | 11:09 PM
Calderone's Avatar
Calderone
Guys i uploaded it here
Right click, save target as, then open it
http://www.calderone-online.com/c4/tpi.mht
