C4 Won't Start
Old Sep 3, 2010 | 07:45 PM
MardiGrasMan's Avatar
MardiGrasMan
Default C4 Won't Start
Car won't turn over.Turned key, it turned over twice and stopped. Starter was changed last week and ran fine til today. I'm sure it's an electrical problem. Checked battery, cleaned cables to be sure. Accessories give a low battery indication. Antenna creeps, windows will not roll. Battery has full charge, clean tight connections. What do I check next?
Old Sep 3, 2010 | 08:02 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
If the battery is OK, then you have a bad connection somewhere. Check the battery ground cable to block and pos. cable to starter.
Old Sep 4, 2010 | 12:02 AM
jfb's Avatar
jfb
You can tell the state of charge by measuring the battery voltage at its terminals. 12.0 volts and lower, discharged, charge your battery up overnight. 12.9 volts and higher, fully charged and linear in between.
Measure the voltage on the battery posts while someone holds the ign in crank position. Battery voltage must not fall below 9.0 volts or the battery is discharged, battery cables need cleaning, or the battery is at the end of its life.
Old Sep 4, 2010 | 01:46 PM
MardiGrasMan
Thanks, it's fixed...It was the Battery after all. It showed 12 volts with a regular tester. Also when I hooked up the battery charger it read Fully charged. I removed the battery and nput it on the charger again and left it, then the charger said replace battery. It's a NAPA battery 2 years old and they replaced it for $31. Thanks
Old Sep 9, 2010 | 10:25 PM
FOXX's Avatar
FOXX
Crazy, I just tried to start my car. Nothing. Plenty of 12volt juice. Clutch in, turn key, all lights do their normal thing but no start. Then, I tried this. clutch out, turn key-hold key, then clutch in= starts fine. You never know. Try it. Must be a switch goin bad or somthing
Old Sep 9, 2010 | 10:28 PM
Harsh20's Avatar
Harsh20
sounds like you just need to change your safety switch on the clutch or maybe just lubricate it.
Old Sep 10, 2010 | 09:07 AM
FOXX's Avatar
FOXX
Thats' what I figured. Assuming that is in my FSM, because I don't know where it would be.
To C4 Won't Start
