coolant temp after head gasket
Old Sep 4, 2010 | 06:12 PM
matt_jahn's Avatar
matt_jahn
Default coolant temp after head gasket
I just did head gaskets, replaced my coolant sensor in the passenger head. and when i fire it up my digital read out is slowly increasing, while my analog gauge will just climb fast. it pegged 260 while digital was reading 160 and it had only been running for maybe 5 minutes. can anyone help make sense of this, could it be because i havent completely bled the coolant, i saw this happening so i quit bleeding at that time
Old Sep 4, 2010 | 06:53 PM
John A. Marker's Avatar
John A. Marker
Did you get the correct sensor? When I dropped in a new engine into my Blazer the part house gave me the incorrect sensor. It was climbing past 260 before the engine was even warm!
Old Sep 4, 2010 | 07:01 PM
tblt44's Avatar
tblt44
try burping it now with the engine off,if air comes out like mine did,thats your problem,I think there may be 2 sesors one for anologe and one for the digital gage.My anologe was pegged also and digital only said 190,shut it off burped it for about 30 sec,everything good now
Old Sep 4, 2010 | 07:15 PM
matt_jahn's Avatar
matt_jahn
i burped it and am still having the same results. it could be the wrong sensor i guess, i thought that sensor over there was for the digital read out though
Old Sep 4, 2010 | 08:11 PM
STL94LT1's Avatar
STL94LT1
The digital temp sensor is in the water pump, analog in the head.
Old Sep 4, 2010 | 08:16 PM
Ape0r's Avatar
Ape0r
Interesting to learn that they are in different spots. My analog gauge reads 255 when my digital hits 228 and kicks the fans on.
Old Sep 4, 2010 | 09:28 PM
matt_jahn's Avatar
matt_jahn
well ive burped it three times now and after letting it cool and doing it again and again im getting a lot of air, how long does it take to bleed an lt1 after doing a head gasket?
Old Sep 5, 2010 | 01:30 AM
JAKE's Avatar
JAKE
Tell us the procedure you're using to burp that air from the system. May be something in your procedure.
Jake
Old Sep 5, 2010 | 08:36 AM
matt_jahn's Avatar
matt_jahn
Once the t stat is fully opened I shut the car off and open the bleed screw untill all steam is gone and I start to get coolant. I've done it 4 times now
Old Sep 5, 2010 | 04:33 PM
matt_jahn's Avatar
matt_jahn
I just burped the system for the seventh time and am still getting air, anyone experience this after head gaskets?
Old Sep 5, 2010 | 05:14 PM
JAKE's Avatar
JAKE
I suggest you follow the procedure in your Owner's Manual. The one for my 96 doesn't mention anything about running the engine, then shutting it down and steam.
You didn't mention the year of your car, but doing it the GM recommended way would be the first thing I do and if that doesn't work I'd then try to find out why. No way to really tell if you have a problem or not without first following the recommended procedure.
Jake
Old Sep 5, 2010 | 10:22 PM
matt_jahn's Avatar
matt_jahn
And would you enlighten me with this procedure
Old Sep 6, 2010 | 03:47 AM
Rodney_Gold's Avatar
Rodney_Gold
Here's an article on how to test the temp readings and bleed the motor
http://www.shbox.com/1/4th_gen_tech2.html
However , if after bleeding you are getting a lot of "air" in the system , I would use one of those thingys that check for combustion gasses in the coolant , especially after changing head gaskets - could be an issue with the gaskets.... Or a cracked head --- hopefully not ...
Old Sep 6, 2010 | 03:43 PM
matt_jahn's Avatar
matt_jahn
I had the heads checkedand resurfaced. I'm still getting air out
Old Sep 6, 2010 | 06:05 PM
JAKE's Avatar
JAKE
Don't you have an Owner's Manual? The small one that comes with the car.
What year is your car?
Jake
Old Sep 8, 2010 | 07:55 AM
matt_jahn's Avatar
matt_jahn
its a 92
Old Sep 8, 2010 | 07:50 PM
JAKE's Avatar
JAKE
its a 92
My car's a 96 so I can't guarantee the procedure is the same for the 92, which is why I suggested you reference your Owner's Manual.
However for the 96, GM cautions that the engine has a specific bleed procedure. That failure to follow the procedure could cause your engine to overheat and can be severely damaged.
The radiator cap is removed, engine off. Bleed screw on the thermostat housing is loosened and coolant is poured into the reservoir. This will force a coolant and air mixture from the bleed screw.
When air no longer accompanies the coolant from the bleed screw you tighten the bleed screw and top off the reservoir with coolant.
The Opti should be covered with several layers of terri-cloth towels/rags to prevent any coolant from getting into the Opti.
Make sure the over-flow bottle (near passenger side headlight) has adequate amount of coolant.
Fire the engine and allow it to idle about 4 minutes. Then add more coolant through the reservoir until the level reaches the base of the filler neck.
Shut down the engine and replace the pressure cap. As the engine begins to cool, any additional coolant that the system needs will automatically be drawn into the cooling system from the over-flow bottle IF all the hoses are tight and leak free.
Jake
Old Sep 8, 2010 | 08:04 PM
Weav's Vet's Avatar
Weav's Vet
Next time take out the thermostat and fill the system from there. You won't have any air pockets.
To coolant temp after head gasket
