1988 Corvette stalls when hot will not start up until cools down.
Anyways, I checked the resistance of my injectors and they were off by a decent margin while hot, and were within spec when cooled down. It would start cold, but not hot and would stall when hot.
When the engine won't start, (1) unplug the connector that you unplug to set base timing. If you can start the car then, it indicates a bad pickup coil. (2) unplug the MAF, if you can start the car then, it's a bad MAF.
In my case it took two tries when the MAF was unplugged to start the car, but it would start on the second try each time the problem occurred, so I replaced it and the problem vanished.
If not that, from what I've read in this thread, you may have a bad coil. Good Luck.
Watch how the pieces come off should be a shim and a washer .Replace pickup clean and lube as needed.
Found no diagnostic trouble codes. Any suggestions?
Work completed:
Cleaned throttle body, replaced MAF, power and burn off relays, new ignition capacitor, pick up coil, ignition module, rotor, distributor cap and spark plug wires, also coolant temperature sender and oxygen sensor, adjusted TPS .54 fuel PSI 38 it is normal. Fuel injectors:
Cold 16.4~16.3~16.3~16.4~16.4~16.4~16.4~16.3.
HOT 17.2~17.0~17.2~17.3~17.2~17.2~17.3~17.3.
When hot and it won't start, I recommend checking for pulses at the ppl/wh wire out of the distributor during cranking. This wire has reference pulses out of the distributor to the ECM and pulses prove that the pickup coil and the HEI module are working properly. An oscilloscope is best to view pulses, but your a.c. voltmeter may indicate output volts on this wire. Try your a.c. voltmeter on this wire when the engine runs to determine if it can measure the pulses. You can also see if there are pulses on the white wire out of the distributor which goes to the tachometer and this wire is connected to the primary of the spark coil, so no pulses means no spark. The spark coil primary gets 12v pulses from the HEI module inside the distributor. If you get no reading on your a.c. voltmeter, first try reversing your voltmeter probes when the engine is running (known pulses) and if your voltmeter doesn't respond, you will need to gain access to an oscilloscope.
Following tests made:
When engine is hot and cuts off, found no diagnostic trouble codes while cranking fuel PSI is OK, but there is no spark tested all fuel injectors:
Work completed:
Cleaned throttle body, replaced MAF, power and burn off relays, new ignition capacitor, ignition module (HEI module), pick up coil, rotor, distributor cap and spark plug wires, also coolant temperature sender and oxygen sensor, fuel filter, adjusted TPS .54 Started up runs great, again engine cut off at normal temp, there is no spark while cranking smell fuel.
The symptoms (no spark when hot) are what happens when you either don't use any grease under the ignition module or put the wrong grease there. It should be THERMAL grease, NOT dielectric grease.
The ignition module gets REALLY hot and will shut down if it overheats.
