420" swap into 88 problems
Jim B aka tpi421Vette is expert with those motors maybe he will pipe in, follow his lead
I would start by going through what is not connected and re-connect. Do you have the ability to put a scanner on the car or datalog? if so see what are the 02 mv.'s doing, I would also check the cts. temp input. If either of those senors are not working correctly that could cause a rich condition.
The 1.8-2.5 is reasonable pulse width, should be a bit more stable, but if not entering closed loop etc. there could be other factors causing this. The maf @7 grams (I suppose this what you mean for lack of info) seems low to me for idle. Typically on a bigger inch motor (400+) I see anywhere from 11-14gr/sec. at idle @operating temp. I would check this out as well.
How are you determining the rich condition? On your scanner (not interior guage), does it show that the motor is reaching operating temperature, if not what does it show? What kind of adjustments are you making, that you state are making it worse ?
For that idle speed the IAC needs to be around 40 cts at idle (@ operating temp). Opening the tb blade (min air screw, and reset) will reduce the counts and smooth out idle and throttle response.
02 sensor numbers should be moving around more instead of staying at 479. I would pressume this was before entering closed loop as you have posted blm numbers. However if its staying at 479 once at op temp, it woulld appear that it might not be staying in closed loop.
Where is the 02 located ? is it heated or ? Is the car going in and out of closed loop ?
If the dash is showing correct battery voltage (low volts), this would typically have it running richer due to the offset add-ons in fueling (in the chip/tune) based on voltage. If that info is correct and the alternator/battery condition improve and then operate at 14 volts, the car will be even leaner.
The rest of the data posted (maf grms, pw etc.) doesn't look too bad but you really need to datalog and more than likely some tuning. It seems like your data is a snapshot instead of data over time and the car will need some work. Data logging will confirm things like the battery voltage (low or not increasing), the 02 numbers (moving or not), closed loop/open loop, etc.etc.
Other important info would be to know what the fuel pressure is currently set at ?
Additonally, when you do get it to come around, I would be very carefull as those small injectors (based on your earlier post of using stock 22# inj. ) will not properly support that ci. and may go static at wot.
Hows the TV cable?
