Power Steering Leak
Old Sep 7, 2010 | 02:40 AM
K87ZZ4's Avatar
K87ZZ4
Default Power Steering Leak
I've got a pretty bad leak coming from the power steering in my 87. It started growling on the way home the other day, I checked the fluid, which was way low and topped it up. After a 5-mile drive, it was growling again and really low.
I noticed fluid on the floor of the garage, so I jacked up the front of the car and it seems to be dripping from the bottom connector on the pump.
Anyone else had this kind of problem with the PS? Does it likely mean the pump has failed and needs to be replaced? Or is it possibly a bad connector? I suppose if you have to get the pulley off to fix a connector, you probably should just replace the pump.
Is this a 1-hour job? Or an all-day job?
Thanks much!
Old Sep 7, 2010 | 09:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The low pressure line on pump bottom is held in place with a gear clamp and may just be loose or the hose may have a hole. Both are fixed easily.
Clean it well at watch at startup, should be a little more obvious where it's coming from.
Old Sep 7, 2010 | 11:33 AM
mashinter's Avatar
mashinter
My '92 had a leak in the pump inlet metal line. I tightened the hose clamp and that didn't help. I replaced the pump...all better.
Old Sep 7, 2010 | 11:57 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
My '92 had a leak along the metal rack-to-resovoir pipe. Replaced it and the leaking stopped. If you replace the connector on the low-pressure line, be sure and use worm gear screw clamps and not the O.E.M. style.
Old Sep 10, 2010 | 02:24 AM
K87ZZ4's Avatar
K87ZZ4
Thanks for the tips--I totally agree about using good hose clamps. Although replacing a hose is simple, in this case getting to it doesn't seem easy since there isn't much room.
Do you have to remove the pulley to replace the hoses? Or, do I just need to take a different angle on it?
Thanks much for the help!
Old Sep 13, 2010 | 01:31 AM
K87ZZ4's Avatar
K87ZZ4
I crawled further under the car and managed to get a better angle to see, and reach, the pump. Looking at the back side of the pump, it seems to be dripping from the pipe that connects to the control valve (from the drawings in the FSM, anyway). The fitting wasn't very tight, so I snugged it up, but it's still dripping.
I'm wondering how a fitting on the power steering pump would work it's way loose anyway???
To Power Steering Leak
