Engine pukes oil when pushed hard.
Old Sep 7, 2010 | 03:06 PM
Bobzilla's Avatar
Bobzilla
Default Engine pukes oil when pushed hard.
OK, so the first event I took the new car to the PCV valve was completely stuck, gunked up beyond belief. So the engine would puke oil out the oil cap and a little out the breather side. REplaced the PCV valve, new engine air filter and it now is fine, UNTIL it gets truly pushed, WOT, late braking and tighter turns on an auto-x course. Let it idle for a minute or two and it stops.
Am I looking at leaky rings? No, I have not run a compression/leak down test yet.
Old Sep 7, 2010 | 03:10 PM
Muffin's Avatar
Muffin
I suspect you answered your own question. I'd run the compression tests
to narrow it down.
Old Sep 7, 2010 | 03:39 PM
BLOCKMAN's Avatar
BLOCKMAN
Leak down test at TDC would be your best bet
Old Sep 7, 2010 | 03:48 PM
thedudeman321's Avatar
thedudeman321
start extremely simply: are you putting too much oil in it?
Even if you think you aren't... are you 100% SURE?!
edit: just saw your profile says you don't have a car? hm....
Old Sep 7, 2010 | 04:09 PM
Bobzilla's Avatar
Bobzilla
5qts of oil, top of the crosshatches on the dipstick. The oil that came out was more sludge than oil. Getting ready to be changed again (500 miles in) to flush it out.
Old Sep 7, 2010 | 04:14 PM
thedudeman321
Might want to look into flushing the engine with ATF or something if you think there's a sludge issue.
Old Sep 7, 2010 | 05:34 PM
Bobzilla's Avatar
Bobzilla
No signs of sludge, just really dirty. PO didn't do much of anything to the car it appears. This oil still looks clean, but I'm going to change it again with another new filter to insure that it is. I run it hard, no point in skimping.
Oil pressure has never dropped below 40, even at idle, sitting in traffic with oil temps climbing towards 220. Car runs solid and it only pukes under extreme use. The car has 143k miles on it. I expect some things to need to be replaced/rebuilt/redone. It's not a show car by any means, but DAMN is this thing fun.
Old Sep 13, 2010 | 01:26 PM
Bobzilla's Avatar
Bobzilla
OK, so it will ONLY push oil out of the oil cap/breather tube when pushed to redline. I pushed it in 2/3 gears this morning (run to almost redline) and it puked oil. Cleaned it up, drove it "normal" (think spirited with a steady cruise) and not a drop after 30 miles.
Wouldn't weak rings cause it to puke ALL the time? Makes no sense why it has to be pushed to it's limits to exhibit this behavior.
Oh, and for giggles a couple clean shots from yesterday:
Old Sep 13, 2010 | 02:27 PM
Keystring's Avatar
Keystring
Here's a silly question.
How good is your PCV valve?
Old Sep 13, 2010 | 02:52 PM
Bobzilla's Avatar
Bobzilla
new. the one I removed was completely clogged.
Old Sep 13, 2010 | 07:01 PM
Slalom4me's Avatar
Slalom4me
Sludge? Perhaps like a chocolate milkshake?
If so, it is possible that your '88 L98 w/ Alum heads may be
experiencing early stages of head gasket or possibly intake
gasket failure. Until you eliminate the possibility of coolant
getting into the oil, it would be best not to run the engine.
Any smell of glycol around the oil filler cap? Any recent issues
with momentary difficulty cranking? Anyone mention seeing
quantities of white vapour from the exhaust as you drive?
Old Sep 13, 2010 | 07:28 PM
Bobzilla's Avatar
Bobzilla
No coolant in the oil, current oil still looks very good (about 900 miles on it), coolant is still pretty green with no signs of oil slicks. No smoke, even on startup (except the black smoke from extended cranking, likely bad FPR). Doesn't burn or use any fluids EXCEPT the oil that gets pushed out past the oil cap.
The oil that was in it hadn't been changed in a VERY long time. The pos filter I took off from a quickie lube had a 5-09 date on it, meaning it likely hadn't been changed since May of '09. I bought it August 2010. It was still full when I changed it.... just DARK brown, borderline "diesel black".
Believe it or not, this isn't my first go around with SBC's of this vintage, and I know my way around the engine bay fairly well. I'm just trying to eliminate all the extraneous stuff before I get too deep.
Old Sep 13, 2010 | 07:44 PM
cv67's Avatar
cv67
St. Jude Donor '05
Could be a little blowby causing the oil to foam some as the oil gets hot.
Some run theirs a quart low when raciing to avoid that.
Old Sep 13, 2010 | 07:49 PM
Rob31's Avatar
Rob31
Do you have a HEI in that or opti ? My distributor gasket was half gone on mine , only leaked when pushed hard .
Old Sep 13, 2010 | 07:50 PM
Bobzilla's Avatar
Bobzilla
I was also wondering if the intake breather or pcv port may not also be a bit clogged considering the condition of the pcv valve and the oil. Clogged enough that "normal" driving it doesn't build pressure, but under high loads and extended upper rpm use it builds pressure because it can't evacuate the pressure fast enough.....
Just a thought. I'll find out one way or another.
Old Sep 13, 2010 | 07:51 PM
Bobzilla's Avatar
Bobzilla
HEI. I haven't noticed any oil at the rear of the engine, all seems to come from the passenger valve cover on top. I noticed the cap doesn't seem to fit well though. Imight try another cap and a new (read: not dried out) breather grommet.
Old Sep 13, 2010 | 09:21 PM
bwiencek's Avatar
bwiencek
Since you replaced the PCV valve and are going to replace the oil cap I'd replace the grommets holding it in and the hoses leading to the intake - if one collapses then it's as useless as having the old plugged up PCV in place.
Once you do that then I'd flush the engine (use a commercial motor flush or diesel/ATF to clean the sluge out) and then run a can of cleaner through the intake (spray carb cleaner through a vacuum port or use seafoam or any other top engine cleaner).
If those don't fix it then you're pressurizing the crankcase beyond what the PCV system can evacuate and it's time to look into a rebuild or a vacuum pump or additional crankcase venting (band-aid fixes)
To Engine pukes oil when pushed hard.
Old Sep 14, 2010 | 07:48 AM
Bobzilla's Avatar
Bobzilla
^ Don't give me an excuse to rebuild and swap cams!
Old Sep 14, 2010 | 10:27 AM
bwiencek's Avatar
bwiencek
If that's what you want then I can come up with all sorts of excuses to pass off on why the motor needs to come out
More power is always a good thing
Old Sep 14, 2010 | 10:39 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Like the C5 Z06 rims on there, Bob. You get your oil issue resolved yet?
