Flexplate holes?
Old Sep 7, 2010 | 10:42 PM
C4vettrn's Avatar
C4vettrn
Default Flexplate holes?
Why are the flexplate holes for the converter a couple o sizes larger then the bolts used? You would think this would allow for movment? I guess with the engine turning the same direction against the side of the bolts it doesn't matter? Any thoughts?
Old Sep 8, 2010 | 12:13 AM
383vett's Avatar
383vett
You're right. The motor is only pushing against one side of the flexplate holes so it shouldn't matter.
Old Sep 8, 2010 | 03:34 PM
C4vettrn's Avatar
C4vettrn
Default Thanks!
The manual didn't show a tourqe for flexplate just flywheel? I assume they would be the same but not sure 74ftlbs. is the flywheel tourqe?
To Flexplate holes?
