Turn Signal Help
Old Sep 9, 2010 | 01:48 PM
ccorvetteracing's Avatar
ccorvetteracing
it seems to be working fine but its a little irregular. Im going to replace the flasher and see what happens
Old Sep 9, 2010 | 02:14 PM
McGirk94LT1's Avatar
McGirk94LT1
Originally Posted by hooked073
Are you saying that if you turn the left on both fronts come on and if you turn right both fronts come on?? If this is the case try this try your 4 ways. see if they work. you can even turn the 4 ways on and off a few times. tell me what happens
No whichever direction I choose, that front signal comes on and stays on. But the rears are only visable if you apply the breaks, in which they light up brighter then the non turning rear lights but dont blink either. Aka if i have the brakes on, turn signal to right, the right rear lights are brighter then the lefts as they should be. But to create a blinking motion, currently i have to turn the stalk left or right, then return it to center, then turn it again. Which is still only visable if the brake is applied. My four ways however, work fine. Thanks btw.
Old Sep 9, 2010 | 03:06 PM
hooked073's Avatar
hooked073
ok you have 4 ways, brake lights, that rules out a few things. I think it is likely turn single switch. I do not have that year wireing diagram but that is the common link for what you have and don't have sorry I could not be more help.
Old Sep 9, 2010 | 03:22 PM
McGirk94LT1
No, thanks for any help. I don't have a repair manual but I have a haynes book for c4's. Should have it in it so I'll start exploring that route.
