Throttle-Body Upgrade
Old Sep 9, 2010 | 12:02 PM
STH's Avatar
STH
Default Throttle-Body Upgrade
Is there a measurable difference between a 52mm and a 58mm throttle-body?
Presently; I have a 52mm BBK on my 1990vette. It’s a 383 with an Edelbrock TPI intake, AS&M big tube runners, 24# injectors, and a modified air box. The vehicle also has Edelbrock Performer (60879) heads.
This year I’m upgrading ; ordered is a USM Stealth Ram, AFR 195 Heads, and 35# injectors. Should I upgrade to a 58mm throttle-body? What improvements would I expect to see going from a 52mm to a 58mm throttle-body?
Steve
Old Sep 9, 2010 | 12:15 PM
engle1147's Avatar
engle1147
Quicker thottle response with the larger TB off idle. I'm not sure you need it though - depends on your what your flow increase demands are. I'm sure others will chime in on this.
Old Sep 9, 2010 | 12:35 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
You need to match the inlet CFM with the amount of air used by the engine. Too much can actually cost you power. I know people running 330-380 RWHP and still using a stock 48mm TB.
Old Sep 9, 2010 | 08:49 PM
LT4BUD's Avatar
LT4BUD
Wonder how much more power they would get if they upgraded to 58mm????
Old Sep 9, 2010 | 11:24 PM
jesredvette's Avatar
jesredvette
Actually, a larger TB would have a more sluggish response off idle, wouldn't it?
Old Sep 10, 2010 | 12:06 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Probably not. On EFI cars, the intake tract (intake runner + head runners) is where the port velocity characteristic is created. Injectors do a much better job of providing the correct fuel to go with the air flow. And, the injectors don't alter it.
By using a smaller-than-necessary TB, you can't really speed up the air per se. By using a larger-than necessary TB, you at least guarantee enough air is available. And, since each part of the intake "chain" creates some form of restriction, reducing the individual components usually results in, at least, some gain.
For the OP, the gain could be enough to make it worth while -- especially if looking for every last 100th.
Old Sep 10, 2010 | 03:18 PM
STH's Avatar
STH
So going from a 52mm to a 58mm on a street car is not worth the cost?
I think I'll sticvk with the 52mm BBK and save the $320.00 for something else.
To Throttle-Body Upgrade
