Asr light?
Old Sep 10, 2010 | 04:14 AM
vetluv's Avatar
vetluv
Default Asr light?
Hello Vette experts, I am planning on buying a vette 96 with 28k miles, and the asr off and service light is on, on the rear axle the tires are 285/40/17 and the other is 275/40/17. The light came on 2 weeks after he bought the 285/40/17? if i were to switch to the same size would the light go away? Thanks guys.
Old Sep 10, 2010 | 06:41 AM
toptechx6's Avatar
toptechx6
Follow this link, then scan down to Sequenced Code Recovery 94 to 96
http://www.corvettebuyers.com/c4vettes/codes.htm
post any codes stored in module 9 and someone will be able to tell you what it indicates.
Old Sep 10, 2010 | 01:03 PM
thedudeman321's Avatar
thedudeman321
I'd start there even if it isn't related to the ASR (which it may be).
Although the difference isn't major, running tires of different heights on the rear (for extended periods of time)can raise hell with the posi.
To Asr light?
