serpentine belt
Old Sep 10, 2010 | 08:24 PM
dramos64's Avatar
dramos64
Navigator
Default serpentine belt
Help. I replaced my distributor and water pump on my 1993 corvette. I tested the engine by starting engine before water pump installation, engine started. After installing the new serpentine belt, engine did not start, I removed the serpentine belt and the engine started.:
Update the engine has nothing to do with the engine not starting. But, i'm still having trouble with my engine. The engine starts when it's cool but dies less than two minutes later.
Old Sep 10, 2010 | 08:33 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Cockpit trouble ....you either bought one too short or installed it wrong.
Old Sep 11, 2010 | 06:17 PM
don hall's Avatar
don hall
Default belt-'93
Your engine does not require a belt to operate. The belt only drives the accessories... alt, pwr str, etc.. The water pump is engine driven.
Check for a loose electrical connection.
Old Sep 11, 2010 | 10:08 PM
thedudeman321's Avatar
thedudeman321
You must've knocked something loose or something. Even if an accessory was 100% seized, it wouldn't stop the engine from starting. The belt would either slip or snap, but I couldn't imagine it being strong than the torque of the starter.
To serpentine belt
