I have a Snapon Solus Pro scanner and when hooked up to the ALDL connector it will not communicate. However when I short with paper clip, I get the code 12, (no DTC)
I'd like to get the Solus to communicate, (to view the data stream), but don't know where to start. Fuse? Wire Harness? What/where should I check?
I selected the correct vehicle, however i don't have an '89 owners or service manual, so I'm going to look at the Solus manual now for the troubleshooting guide.
