have heard that law enforcement agencies routinely disable the ABS due to complaints by operators (LEO's) that braking is compromised by the ABS rather than aided.
have heard that the LAS (lateral accel sensor), that MUST disable the ABS during turns to prevent ABS braking reduction at one side from causing loss of control, will also shut off the ABS if the vehicle is in a skid sideways (just when most needed)
have heard that some owners unplug the electrical connector in the ABS compartment and remove the ABS warning bulb from the DIC and enjoy better brake performance and 'pedal feel'.
have heard that a local owner of a GM pick-up truck that was only weeks old, rammed the side of the local convenience store when a small piece of rust somehow found its way into the ABS sensor interface, causing the ABS to activate and reduce brake function at one wheel (how all ABS operates AFAIK) , extending stopping distance to beyond the building exterior surface.
i RECOMMEND that you do no modifications to your brake system in any manner.
Find a shop that will let you watch what they do or buy your own Tech 1 for about 1800 if you can find one. I have never heard my ABS self test the light blinks and that is it and it has never gone off no matter how hard I try. If the ABS needs bleeding it is going to be messy and hard to avoid send a letter to GM about the poor design like they actually care.
Well what did it read for codes?
Did you run the self test to cycle the system?
There are bunch of funtional tests with a tech1 listed in the FSM.
Have you ever tried to activate the system on a dirt road or very wet/slippery one?
Could it be a short or failure of the indicator lights / electronics?
If it will not read any codes / connect to the ABS module and there are no blown fuses what can it be other than the ABS module? Do you have a FSM? Have you checked for power and ground at the ABS module etc.?
The ABS is dead in my 91 and NOBODY has a clue as to what it might be.With as my of these cars there are out there I know Im not the only one that has had the ABS die.The system is the same from 86-91 I believe.I want to hear about all the problems people have had.I can fix it if I find the problem.Im not going to go through all the stuff Ive done but I will say it wont pull any TCs and wont communicate with any scanner Ive used,all I get is SERVICE ABS on the panel.Let hear what ya got.
Simple stuff:
Is the "BRAKE" light on? (Is your brake fluid topped off? On my '92, the fluid level sensor is way up there, so even a little low will kill ABS/ASR)
Simple stuff:
Nobody is wiling to do this and to be honest,I cant blame them.They have cars waiting for service the last thing they want is to work with some neurotic Corvette owner.
I doubt very much that any dealer will turn down earning a fee for merely running a diagnostic test for a customer without doing the indicated repair. The dedicated tester that dealers use is the best possible way to find out why your ABS is not working properly. Even if you were turned down by one dealer, talk to all the other nearby dealers for a diagnostic test, it is the best possible way for you to find out what the problem is. Before talking to the service departments, and before you leave home, remove the chip on your shoulder, open your closed mind, and take off the defeatist attitude and put in the closet. Sorry, but thats the way I see it.
[QUOTE=j Before talking to the service departments, and before you leave home, remove the chip on your shoulder, open your closed mind, and take off the defeatist attitude and put in the closet. Sorry, but thats the way I see it.[/QUOTE]
Dont waste my time with this bull$hit,you have nothing to offer here so do everybody a favor and -HELP- somebody else.You got nothing here so move on.
I had the same problem; Solution for me: Remove the ABS completely, connect the brake lines directly to the Master Cylinder. Problem solved. Please note that this was a decision I made based on the cost to replace the ABS unit. I do not advocate the modification of any factory designed system. I have two corvettes (1986 and 1987) and I cannot tell any difference in the braking. You make your own decision.
If you would post what you have tested and the results it might make it easier to help you. I need to do some testing on mine as I do not get the self test everyone talks about the abs light blinks when I first drive after start-up I can not lock up the brakes with new rotors that got very thoughly cleaned and hawk hps pads and drm bias spring in a new master cylinder. It did go off once on a very wet road. There is plenty of brake dust on the front wheels and very little on the rears.
Can you get codes stored in every other device CCM C68 climate control Air bag ECU etc.?
So far Ive used 2 different controllers,2 different accelerometers,replaced all 4 relays,checked for 12 volts at controller,same for grounds.Now,just yesterday I found that the motor has its own ground while the ABS has a ground,Ive been checking the motor ground while there is at least 3 grounds in the system.There is one ground at the bell housing I need to take a look at.I think now Im looking at a power supply issue.On a side note here,keep the garbage comments out of this thread,Ive been a member here for years,have givin advice in countless threads when somebody needed a hand and this is the only time Ive hit a wall while looking at a problem and needed advice.When the injectors died in the car taking it to a dealer was never a thought,talk to some people,get parts and have at it so I know Ill find the issue with the ABS.
I also have a 91 with non functional ABS. I have been so busy with other vette issues that I have yet to tackle ABS so I am very interested in what you find out. I have been disappointed in general with the braking, seems like there is no rear compared to my past sports cars. I appreciate the fact that you are trying to fix this yourself, which is what I thought this forum is about. Not how many times people tell you to go to dealer service. 2 cents.....
Im getting close,I found an issue and should know something here pretty soon.The ABS in a ZR-1 is the same for all Corvettes.You would think with as many 86-91s out there it would be easier to find info.If I can fix this I can find the problem with the ABS.[IMG][/IMG][IMG][/IMG][IMG][/IMG]
And the wire goes to? Color at least and where in the dash? This might help others too.
Dave
Pink and black wire at over voltage relay.Power goes through this relay before it goes to the controller.This explains why the system was completely dead.
I have come to the conclusion these cars are not that complicated on paper but the way they are built service parts and test points are buried in impossible to get at places without major disassembly. An example would be if they put the ECM under the dash and relays and second fuse box there it would have saved a good deal of time later.
Jeff did you find out where was brake was? Was it at the fuse block or the connector, or was it cut in between?
David Fulcher
Hi David.When I removed the CDM box years ago I disconnected all the plugs in the area for easier removable.I found one of the pins in one of the plugs pushed out.Thanks again David for all your help on this.Theyre asking for your ABS knowledge over on the ZR1.NET site.
