LT1 wire replacement
Mar 30, 2002 | 08:03 AM
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
do I really need to pul the alternator and all that crap???? whats my best bet??? :cry
Mar 30, 2002 | 09:21 AM
Re: LT1 wire replacement (My 95)
Pass side nothing needs to be removed. Driver side, remove the ASR motor from it's mounts and push to the side, center wheel well shield, tensioner and belt, loosen the power steering pump. That's all I do and I don't think it's too bad a job. Just a few hours taking your time.
Mar 30, 2002 | 09:47 AM
Re: LT1 wire replacement (RichS)
Thanks Rich. I just did the plugs this mornin, not too bad and already have the ASR out, so hopefully it wont be too bad
Mar 30, 2002 | 10:57 AM
well, the passenger side was a snap. I looked at the drivers side. Once I stop crying, Ill go for it
Mar 30, 2002 | 10:58 AM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
GOOD LUCK :(
Mar 30, 2002 | 11:09 AM
Cruise-In III Veteran
Re: LT1 wire replacement (mackeyred96)
Hehehe.... ahh.. better you then me :)
I took the alternator out just so you can see what bolts to remove on the PS pump.. there are something like 5 bolts... 3 of which loosen the pump. Some say you can get them from under the car without taking anything off, maybe on a lift, but lying on the ground? not me.
Mar 30, 2002 | 11:49 AM
Re: LT1 wire replacement (Springer's 95)
remind me when I get to the cruise in to kick somebody in BG's azz. someone has to be responsible for this
Mar 30, 2002 | 12:59 PM
theyre all on and connected. I just have to put all the componenets back togethert after I find something to drink
