Oil Temp Sensor Replacement - L98 - Any Tips?
Old Sep 17, 2010 | 04:11 PM
Bucs34's Avatar
Bucs34
Default Oil Temp Sensor Replacement - L98 - Any Tips?
Hello, I have tracked my false oil temp readings back to the sensor being bad. I have an 85 L98 and in my research Ive found that the sensor is located above the filter. What Im wondering nos is if anyone has any words of wisdom before I go after this job. Will I lose any oil? Is it a simple procedure? Any and all advice is greatly appreciated.
Old Sep 17, 2010 | 04:37 PM
Keystring's Avatar
Keystring
The oil temp sensor is actually above the pan level, so I don't think much, if any, oil would come out.
Just take out the old one and put the new one in.
It's pretty simple.
Old Sep 17, 2010 | 04:41 PM
Bucs34's Avatar
Bucs34
Thats what I figured but had to check. Some cars turn simple things to hard projects!
Old Sep 18, 2010 | 09:23 AM
Steve59's Avatar
Steve59
I would check and clean the connection first to see if that makes a difference. Lots of times when the oil filter is changed, that connection gets knocked around. It's also pretty dirty under there at that spot.
Old Sep 18, 2010 | 10:36 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
It's pretty simple.
Just do it with the engine off or you'll get some!
Old Sep 18, 2010 | 08:07 PM
Bucs34's Avatar
Bucs34
Thanks for the advice! It really was easy...took about 10 minutes to get the sensor loose. However, finding a new one was a different story. Nobody around me had them or even heard of it. One place told me it would cost $130!!!!! Do I need to order it online?
Old Sep 18, 2010 | 08:16 PM
Bucs34's Avatar
Bucs34
Heres pictures of the sensor I took out. It was directly above the oil filter and it was sitting on a little ledge sort of area.
Old Sep 19, 2010 | 09:52 AM
Bucs34's Avatar
Bucs34
Looks like ill be ordering it from there. I was expecting to pay maybe $30. Its insane how expensive a little sensor is.
Old Sep 20, 2010 | 08:57 AM
Keystring's Avatar
Keystring
Ecklers has them for $45.99
http://www.ecklers.com/corvette-oil-...1981-1989.html
Old Sep 20, 2010 | 09:15 AM
Bucs34's Avatar
Bucs34
Keystring- Nice find! I looked online there too, don't know how I missed it.
Old Sep 20, 2010 | 09:19 AM
Keystring's Avatar
Keystring
Is this the same thing just a different name?
Sure looks the same...
Old Sep 20, 2010 | 09:54 AM
Bucs34's Avatar
Bucs34
Looks the same to me. Autozone told me they didn't have it. But the woman also asked me what make my Corvette was....so maybe ill try again with a different clerk.
Old Sep 20, 2010 | 10:01 AM
Keystring's Avatar
Keystring
Ask them for an oil temperature 'switch'.
It's the way they've got it listed, instead of a 'sensor'.
The one listed is for an 87, but it should be the same.
Old Sep 20, 2010 | 10:06 AM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VIII Veteran
Best to tell them AZ ****'s the part number. Ask 'em if they have PS201 and take it from there.
Old Sep 20, 2010 | 10:16 AM
Keystring's Avatar
Keystring
Good idea!
Old Sep 20, 2010 | 10:22 AM
Bucs34's Avatar
Bucs34
Thanks all. Next time I go in I'm bringing the PN!
Old Sep 20, 2010 | 10:26 AM
Keystring's Avatar
Keystring
Call 'em first.
If they don't have it, then can order it from another store.
Saves gas too!
Old Sep 20, 2010 | 10:56 AM
onedef92's Avatar
onedef92
Call 'em first.
Saves gas too!
And, look online first at the AZ web site. You have to do the "heavy lifting" for a lot of those guys over there.
To Oil Temp Sensor Replacement - L98 - Any Tips?
