Iac adjust
Old Sep 17, 2010 | 06:00 PM
RICOWEB's Avatar
RICOWEB
Default Iac adjust
Hello ,does anyone know the procedure on adjusting the IAC on a 1994 LT-1 engine ?Car starts but will not idle ?
Old Sep 17, 2010 | 08:20 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
There is no adjustment. Provided that the pintle isn't busted from mis-handling, and it's reset properly, there's nothing else to do.
Old Sep 17, 2010 | 08:54 PM
JAKE's Avatar
JAKE
GM says to depress the throttle a little, while held that way, start the engine, release pressure on the throttle and let the engine idle 5 seconds. Shut down the engine for 10 seconds the restart the engine normally. Times corrected by me per FSM.
I looked up the times and they're now shown correctly, above.
Jake
Last edited by JAKE; Sep 17, 2010 at 09:00 PM. Reason: Correct the times - IDLE for 5 seconds; OFF for 10 seconds
Old Sep 18, 2010 | 01:13 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
That's the last part of the L98 procedure.
If it's the same as the early L98s, see this thread.
Old Sep 18, 2010 | 05:10 PM
JAKE's Avatar
JAKE
I took that info from the 96 Vette FSM.
I just checked the link you posted but didn't see the IAC adjusting procedure that I listed earlier. The link you posted is primarily about the TPS. What did I miss?
Jake
Old Sep 18, 2010 | 08:28 PM
GREGGPENN's Avatar
GREGGPENN
I read the linked post a couple of days ago. After re-reading, I realize the info is incomplete.
My 89 FSM, quotes steps 2 thru 9 (under the "Procedure" section of the post I linked). In my FSM, steps 2-9 are the prelim steps before the IAC reset.
After step 9, the steps you posted, Jake, are to finish the IAC "reset". I guess the real question is whether it's necessary to fully retract the IAC before performing the steps you posted. (That's what steps 2-9 in the linked post accomplishes.)
Old Sep 18, 2010 | 08:51 PM
JAKE's Avatar
JAKE
My 89 FSM, quotes steps 2 thru 9 (under "Procedure" of post #) as the prelim steps before the IAC reset.
Unknown. I didn't see any mention of jumping the ALDL in my 96 FSM.
I do recall using the jumper method on the 86 Vette I use to own.
Jake
Old Sep 19, 2010 | 08:23 AM
anciano's Avatar
anciano
If it was me I'd pull the IAC, disassemble it and inspect the air hole and/or pintle for blockage or a broken pintle spring. Clean the throttle body while you are there. It's a very simple procedure.
To Iac adjust
