oil pressure?
Old Sep 19, 2010 | 05:11 PM
Munstervette's Avatar
Munstervette
Default oil pressure?
i have a problem when im driving my oil pressure sits at like 45-55 but when i stop it tells me my pressure is low usually 0-5 but once i start moving again it goes back up to 45-55. ive checked my oil on many occasions and my oil level is good. any ideas what could be wrong?
Old Sep 19, 2010 | 11:40 PM
JAKE's Avatar
JAKE
If you're running 5W30 move to 10W40 to increase the oil pressure during at idle, fully warmed up operating temperature.
Other options involve buying and changing parts. Mechanical oil pressure gage, oil pressure sender, oil pump spring, oil pump, rebuild, etc.
Jake
Old Sep 20, 2010 | 12:15 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
I would temperarely install a mechanical gauge to see if the readings are correct. If they are, something is wrong. How many miles on the car?
Old Sep 20, 2010 | 10:40 AM
Munstervette
95k on the engine. i might just redo the engine soon within the next 6 months, trying to decide if i should bore it over or not any advice?
Old Sep 20, 2010 | 10:47 AM
383vett's Avatar
383vett
Old Sep 20, 2010 | 11:05 AM
0Paul Ruggeri
Former Vendor
It depends on what you find once the engine is torn down. Typically a .030 overbore is what's done.
Old Sep 21, 2010 | 01:27 PM
Munstervette
yes this is what ive been told. ill have the money starting november im hoping to have it done right when i come back from deployment. i want to redo the hole car. i cant wait . thanks for the advice ill get to it
To oil pressure?
