Are they all the same?
Old Sep 23, 2010 | 10:52 PM
IBVETN2's Avatar
IBVETN2
Default Are they all the same?
Are L98 blocks the same as any other gen1 350 blocks?
I have heard that the iron in the vette blocks is a different alloy than a standard 350 block.
Also are all 87 and newer blocks made for roller cams even if they didn't come with one?
Was wondering if I need to stay with my vette block or if I can use a junkyard piece for a rebuild and have the same thing.
Old Sep 25, 2010 | 02:33 PM
IBVETN2's Avatar
IBVETN2
just a bump hoping someone has any info on this. Thanks
Old Sep 25, 2010 | 04:59 PM
Calderone's Avatar
Calderone
bumpo !
Old Sep 25, 2010 | 05:02 PM
tblt44's Avatar
tblt44
vette block same material as all others. nothing special.
Old Sep 25, 2010 | 09:10 PM
ZBRA's Avatar
ZBRA
Originally Posted by IBVETN2
Are L98 blocks the same as any other gen1 350 blocks? I have heard that the iron in the vette blocks is a different alloy than a standard 350 block.
Same iron. Some people like to believe "vette" parts are always better.
Yes, all '87 & later have the studs for the lifter hold down, even the truck blocks with non-roller cams.
If you are going to go that route, get a vortec block from a 96-98 C/K Truck / 96-99 GM SUV / 96-02 GM Van.
Old Sep 25, 2010 | 10:32 PM
vetteoz's Avatar
vetteoz
1 pce seal blocks are machined for the roller hardware whether roller cam was fitted or not
Many truck blocks are 4 bolt mains
Old Sep 25, 2010 | 10:40 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
My 89 vette has a truck motor in it.
Old Sep 26, 2010 | 01:02 AM
ZBRA's Avatar
ZBRA
Just take the truck dished pistons out, put some flat tops in, and you have a strong short-block ready to go.
Old Sep 26, 2010 | 03:16 PM
IBVETN2's Avatar
IBVETN2
If you are going to go that route, get a vortec block from a 96-98 C/K Truck / 96-99 GM SUV / 96-02 GM Van.[/QUOTE]
Are these blocks 4 bolt? maybe a forged crank or a cast nodular like the l98?
Old Sep 26, 2010 | 03:24 PM
Keystring's Avatar
Keystring
A lot of the truck and van engines are 4 bolt but that wouldn't make any difference since your corvette engine isn't.
All L98's are 2 bolt main.
Old Sep 26, 2010 | 06:36 PM
WW7's Avatar
WW7
The 383 Pete K built me used a truck block, its the best way to get a cheap 4 bolt main. But Pete has built some strong motors with 2 bolt mains, I think he told me the 383 he had in his Vette was 15 years old and it saw some serious track time with no problems...WW
Old Sep 26, 2010 | 08:44 PM
rodj's Avatar
rodj
L31 's from the 3/4 & 1 ton trucks are
http://paceperformance.com/index.asp...&ProdID=225981
Old Sep 26, 2010 | 09:37 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I also used a 4-bolt main block out of a 350 PU for my 383. I believe they were in GM trucks from 87ish to 92ish. Maybe longer.
I considered that an upgrade from the factory 2-bolt block. Both blocks are 638 blocks with the same alloy.
Old Sep 26, 2010 | 11:16 PM
IBVETN2's Avatar
IBVETN2
But it would save me the time of installing splayed 4bolt caps on my 2 bolt L98 block
Old Sep 26, 2010 | 11:29 PM
IBVETN2's Avatar
IBVETN2
is the 638 the last 3 digits of the casting number? Is there a different casting number for the 4 bolt blocks so you don't have to pull the pan to look?
Old Sep 26, 2010 | 11:58 PM
johnnyevans's Avatar
johnnyevans
If you're going the splayed mains route, use a 2 bolt block, it will be marginally stronger, there's more metal down there around the main cap web.
rodj's Avatar
rodj
is the 638 the last 3 digits of the casting number? ?
638 is same block casting on my '93 truck block and my '89 L98 .Both 2 bolt . You will find it listed as a early 1 pce seal block ('86 - '94 )
Vortec L31 4 bolt block for my 383 is 880 ; same as used for ZZ4 Crate engine ('96 -'00 )
To Are they all the same?
Old Sep 27, 2010 | 01:28 AM
GREGGPENN's Avatar
GREGGPENN
Doesn't splaying a 2-bolt cost less too? With a 4-bolt, don't you have to get new caps (e.g., 2-bolt caps)?
638 is just what's stamped on the block for 4-bolts and 2-bolt 1-pc RMS. As such, I'd think their metal content would be identical. That's the only reason I mentioned it (referring back to the OP question about alloy).
Old Sep 27, 2010 | 07:29 AM
Keystring's Avatar
Keystring
Umm.. true..true..
Old Sep 27, 2010 | 11:09 PM
IBVETN2's Avatar
IBVETN2
Does the L31 Vortec either 2 0r 4 bolt mains have powdered metal rods? Not sure what a powdered metal rod is. Are they better than the X rods that are in the L98?
Does the L31 have a better crank than an L98?
