Fuel pressure on injector change
Old Sep 23, 2010 | 11:14 PM
samsonb's Avatar
samsonb
Default Fuel pressure on injector change
I changed the injectors on my 89. I put in the Bosch III and I broke the rail down to change the o-rings. Before I took anything apart, with the key "on", my pressure would go to something like 40 and hold.
After changing the injectors and bolting down the rail and lines. I hooked up my pressure tester and primed the system a few times with the key "on". I noticed my pressure keeps dropping. Though after priming it several times over an hour or so, it seems to hold better as it was dropping fast.
Last I checked, the pressure at key "on" would go to 42. Then drop straight to 38 and start slowly dropping.
The injectors, send/return lines, and o-ring connections on the rail are all dry. So, I figured after several hours of priming and checking that I would have found something leaking by then. Or would this pressure drop be normal till after you run the car?
Old Sep 24, 2010 | 02:01 AM
JAKE's Avatar
JAKE
I removed the Schrader valve, screwed on my Accel fuel pressure gage then turned the key to ON. Pressure went to 46 psi and held steady for over an hour which is when I terminated the test.
Jake
Old Sep 24, 2010 | 07:38 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
I would run the engine to get all the air out of the fuel system before doing a fuel pressure leak down test. You have already checked for fuel leaks so put it all back together and crank it over.
Old Sep 24, 2010 | 08:53 AM
samsonb's Avatar
samsonb
That is what I was thinking with regards to air in the system. As I noticed the pressure started holding better the more I primed it, but still wasn't what it was before.
Do you know if it is normal for the FPR to make a noise when you move it? I know it has a spring in it, but I noticed it sounded like the spring was loose when moving it around when I broke the rail down.
I may try pinching some lines at the tank and see what that does before I put it back together.
Old Sep 24, 2010 | 10:44 AM
Lemme's Avatar
Lemme
St. Jude Donor '10
Don't know.
Old Sep 24, 2010 | 02:06 PM
Rich Silvestris's Avatar
Rich Silvestris
St. Jude Donor '05
100%
I had same effect after injector and FPR replacment on my 87. No matter how much I bled it through the gauge, the pressure dropped after a key actuation of the pump. After running the engine, no drop.
If you still get a drop after running the engine, there are other problems to solve.
To Fuel pressure on injector change
