Building a Noid Light
Old Sep 23, 2010 | 09:30 PM
8valve's Avatar
8valve
Default Building a Noid Light
I picked a up 2 High Intensity White LED's and a pack of 680 ohm resistors.
I was reading in the archives that to build a Noid Light, take a LED and put a 680 ohm resistor in series with the LED.
Ok, that does not tell much. LED's have 2 leads, one short, one longer. Which lead gets the 680 ohm resistor .
How do you tell the correct polarity of the LED/Resistor when plugging it into the Injector connector.
8Valve
Old Sep 23, 2010 | 10:18 PM
pr0zac's Avatar
pr0zac
you buy the set for like $20 from the parts store and make it easy on yourself
Old Sep 23, 2010 | 10:25 PM
8valve's Avatar
8valve
Thank You, I did not know you could buy them so cheap. Off to NAPA tomorrow
8Valve
Old Sep 23, 2010 | 11:01 PM
pr0zac's Avatar
pr0zac
http://www.google.com/products/catal...CCUQ8wIwBjgU#p
Old Sep 24, 2010 | 12:26 AM
jfb's Avatar
jfb
It doesn't make any differerence at all which lead you connect the 680 ohm resistor to. On LED's, the short lead is the cathode and this lead should go to the injector socket pin with no voltage on it and the other lead should go to the injector socket pin that has 12v on it.
Old Sep 24, 2010 | 12:57 AM
86PACER's Avatar
86PACER
$25 at Autozone. You can either rent it or buy it.
Here
Harbor freight has an even better set with more adapters plus IAC testers. I think it's $30-$40.
To me it isn't even worth the time trying to make one.
http://www.harborfreightusa.com/usa/...o?itemid=97959
Old Sep 24, 2010 | 02:14 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Here
I bought the HF kit and it has everything you could ask for in a noid set. No way would I take the time to build one with this set readily available, and I like to fabricate.
To Building a Noid Light
