Headlight motors keep running
Old Sep 27, 2010 | 11:16 AM
89vette's Avatar
89vette
Default Headlight motors keep running
I haven't cycled my headlights for a few years and one opened halfway and then was "loose" and flopping around. I noticed that both motors keep running a while after they are closed or opened. Does this mean the Derlin gear is stripped?
Old Sep 27, 2010 | 12:35 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
That's a typical symptom, yes. Check this link for replacement info.
http://www.corvettefever.com/howto/33098/index.html
Old Sep 27, 2010 | 12:38 PM
engle1147's Avatar
engle1147
Most likely you just need to replace the factory "goo" that dried up and failed. Repair can be as simple are installed a set of bushings to replace the goo.
Make your own or order these (3 bushings per headlamp motor):
http://www.ecklers.com/corvette-head...1988-1996.html
Old Sep 27, 2010 | 12:55 PM
aklim's Avatar
aklim
My driver side would open up but it kept running for a while till it stopped itself. Passenger side was fine. I decided not to go with the bushing fix and go with the replacement of the gear and bushing. I also replaced the other side. The driver side was dust and the passenger side was ok but the stuff they put there had already elongated in shape.
http://www.ecklers.com/corvette-head...Product_Upsell
Old Sep 27, 2010 | 03:31 PM
89vette's Avatar
89vette
Thanks. I ordered new gears and bushings
Old Sep 27, 2010 | 03:46 PM
aklim's Avatar
aklim
The bushings will require some filing down to get it right. DON'T be tempted to file a huge bunch off. File a little off, insert it into the bronze gear and put the top piece on and make sure it fits. 2nd and 3rd one, do the same.
To Headlight motors keep running
