Fuel Management Problems
Old Sep 27, 2010 | 01:12 PM
DevilDogg666's Avatar
DevilDogg666
2nd Gear
Default Fuel Management Problems
I have an 85 C4 with an L98 350. It also has a burn off module that apparently is supposed to switch power to the MAF sensor. If I just jump power from the ignition switch to the MAF sensor, will this cause any adverse fuel management problems or does the freaking burn off module HAVE to be in the loop in order for this engine to run properly. Having a hard time finding another burn off module cheaply and i'm ready to shade tree this car slightly just to get it running properly. Any help is appreciated.
Thanks - Andy
Old Sep 27, 2010 | 02:09 PM
Keystring's Avatar
Keystring
Found this on fleabay... cheaper than retail..
http://cgi.ebay.com/ebaymotors/85-19...Q5fAccessories
Old Sep 27, 2010 | 03:41 PM
DevilDogg666
2nd Gear
I saw that too, i'm just wondering if I jump power directly to the MAF sensor through the Burn off Module connector will that work just as well or will that cause problems. Thanks for lookin out, though.
To Fuel Management Problems
