Wheels
Old Sep 29, 2010 | 03:20 PM
IGOFASTERINMYVETTE's Avatar
IGOFASTERINMYVETTE
Default Wheels
I was considering 19" C5 5-spokes all the way around on my '96 to go bigger, lower and loose the stagger. Is there a way to do this with the OE wheel? I would also consider a repro in order to accomplish this.
Any info would be greatly appreciated.
Old Sep 30, 2010 | 07:40 AM
87 vette 81 big girl's Avatar
You Need Wheel Adapters to set the Rims and Tires Correctly into Each
Corner Wheelhouse of Your Corvette.
Otherwise with Factory C5 GM Wheels, They would be sitting in about 3/4INCH to far Inward.
Vette Brake Products in Florida sells the wheel adapters You Need.
Check their Website out too. And send off Your Name and address to them to get a free paperback catalog. Just received mine in the mail this Monday. You will get your catalog in about 1 week like I did.
Search the Archives for more info on Wheel adapters for C4's, and in the C3 Archives too. The C3 Guys use our C4 wheels on their cars Also, for Closed Course Road Racing.
There are Dozens of Great tips in the both C4 & C3 Corvette Forum Archives dating back to 2001. Take a few hours for you to read them all. But make time to read them all. Its worth it.
We had some Very Sharp Corvette Owners back then and What I Would Call High Level Racing Mechanics.
I recently Purchased a set of 1990 ZR-1 Factory Wheels and Tires(CAME FROM A 19,000 MILE CAR) from another Forum Member and Installed them on my 1987 Convertible. I read the Archives in C4 & C3. That answered my question on what I needed to do to install them onto my car.
The 1984-1987 cars use a 38 mm wheel offset with 9.5inch X 16inch wheels.
The 1988-1996 Cars use a 56 MM Wheel Offsets.
The 1990-1995 ZR-1 Rear Wheels use a 36 MM Wheel Offset.
Those Giant 11inch X 17inch Rear Rims with Good Year GSC's P315/35ZR17 Tires Fit Perfectly under the Rear Wheelhouses of my 1987 VERT. No Wheel adapters required in the Rear.
Do Your own Research. Its Very Worthwhile.
BR
Old Sep 30, 2010 | 10:38 AM
Pwnage1337's Avatar
Pwnage1337
...from what I've seen here, all the cars that are 88+ can mount C5 rims without spacers..
did the C5 thin spokes come in 19"? I thought they were 17"
I have an 85 and I had to use spacers, I am running 19x10 rear, 18x8.5 front C6 GM rims. They sit perfectly flush with 3/4" spacers. i think they are 3/4" not sure
Old Sep 30, 2010 | 11:04 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Factory C5 wheels will fit just fine on his '96 without using adapters.
Old Sep 30, 2010 | 11:05 AM
RollaMo-LT4
Factory C5 wheels did not come in 19" size.
To Wheels
