Does Water Wetter Actually work?
Old Mar 31, 2002 | 09:28 PM
NoWorries's Avatar
NoWorries
Default Does Water Wetter Actually work?
I'm planning on getting some tomorrow, I've heard from a few people that it works, but I'm still really sceptical.
If you know how it works, please explain. :cheers:
Old Mar 31, 2002 | 09:39 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Does Water Wetter Actually work? (NoWorries)
I've only tried it in a 50/50 coolant mixture and used only one bottle. I noticed about 5* reduction in temp. This summer I'm going w/ 2 bottles and 100% distilled water. :cheers:
Old Mar 31, 2002 | 09:48 PM
TNTC4VETTE's Avatar
TNTC4VETTE
Will work for HPDE time.
Default Re: Does Water Wetter Actually work? (NUckINg FuTS)
I'm running a good bit cooler after flushing my radiator completely and using water wetter...but my water pump is on its way out...too much time with the old junk in there, and the entire system's corroded looking
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I saw a slight drop in temp.
Old Apr 1, 2002 | 12:42 AM
scorp508's Avatar
scorp508
I dumped a bottle into my 50/50 mix and showed an average of 15 degree cooler temps.
Old Apr 1, 2002 | 01:50 AM
rocketfinger's Avatar
rocketfinger
I've used it in a variety of different vehicles and have seen very consistent 10-15 degree temperature drops. As far as how it works, I may not be the best equipped, but here goes; my understanding is that it contains a surfactant (or flocculent or some such thing) which breaks the surface tension of the coolant and makes for more efficient heat transfer through the interfaces of the engine-block/coolant and coolant/radiator-tube-wall respectively. Physics and chemistry gurus will probably begin to make me look foolish almost immediately...
[Modified by rocketfinger, 6:04 AM 4/1/2002]
Old Apr 1, 2002 | 07:35 AM
Sharky Guam's Avatar
Sharky Guam
Default Re: Does Water Wetter Actually work? (rocketfinger)
You guys are on the right track. Water Wetter contains chemicals that make it a better heat conductor. It easily transfers the engine heat to the water and then to the radiator fins. Without going in to detail it is a patented formula that is probably the best thing out there right now. I have used it on drag cars , off road buggies that have endured the Baja 1000, atv four wheel racers that also endured the Baja, Supercross racing dirt bikes that run high rpms for 45 minutes at a time,and high horsepower street race cars that normally give me fits on stop and go city driving. I have seen temperature drops of as much as 20 degrees. The lubricating properties have also helped the water pump seals. It is very safe with all metals including aluminum heads and manifolds that are prone to internal corrosion. I cannot say anything bad about the product with the exception of the high price. Until something else comes along, it is this racers choice. :cheers:
Old Apr 1, 2002 | 08:27 AM
DON M's Avatar
DON M
It reduces the surface tension of the water and increases the heat transfer coefficient between the fluid and the metal surface. (reduces the little bubbles like those that form on the bottom of the pot when boiling water). The real gain is at that surface. Thermostats may keep temps up in the cooling system.
The reason it doesn't work so well on a street car is that anti-freeze reduces its efficiency. On a track car it works very well.
Old Apr 1, 2002 | 10:33 AM
85 Dave's Avatar
85 Dave
It works best with no anti-freeze present. I've seen up to a 20 degree reduction in a race car. If you have a 50/50 mix, it will help a little, maybe 5-10 degrees.
Old Apr 1, 2002 | 10:56 AM
Dave95C4's Avatar
Dave95C4
Here's what may be a rather elementary question. I flushed/refilled my coolant last summer (50/50 mix of distilled water and Dex-Cool) when I put the 160 stat in. Can I just add in a bottle of water-wetter, or should I pull out 12oz. of the coolant mix first? Don't want to overfill, if that's going to be a problem. I just thought about that before I dumped the bottle in...thought I'd ask first.
Dave
Old Apr 1, 2002 | 01:11 PM
BBA's Avatar
BBA
Default Re: Does Water Wetter Actually work? (Dave95C4)
From what I have heard, it works pretty well if you simply drain the coolant out of your radiator and add the water wetter, then top it off with distilled water. This does leave some antifreeze in the block to mix, but no one said that was a major detractor of it's cooling ability.
Old Apr 1, 2002 | 02:58 PM
ROADAPPLE's Avatar
ROADAPPLE
Default Re: Does Water Wetter Actually work? (BBA)
That's the procedure I used and it woorked well. It left enough anti-freeze so I did'nt worry about the cold weather.
C44EVER
Old Apr 1, 2002 | 08:04 PM
CFI-EFI's Avatar
CFI-EFI
Does Water Wetter Actually work? YES!!! Just like everyone above has stated. Also, it cools down more quickly, between rounds at the strip.
You cannot over fill the cooling system. Just don't let it pour out on the ground. Too expensive to waste.
Old Apr 1, 2002 | 11:49 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
Yes...it works!! :yesnod:
Old Apr 1, 2002 | 11:51 PM
dwaltz's Avatar
dwaltz
I tried Water Wetter and another brand also, with no results at all. I am running antifreeze, so maybe that's the problem.
Old Apr 2, 2002 | 12:25 AM
Lone Ranger's Avatar
Lone Ranger
Anyone know if it would work to extract an equal amount of coolant out of the highside tank with a device and then pour in a bottle of Water Wetter into the highside tank? Just had a coolant flush and fill a week ago.
[Modified by 95_C4_convertible, 10:26 PM 4/1/2002]
Old Apr 2, 2002 | 12:40 AM
Dave95C4's Avatar
Dave95C4
How often do you guys change your coolant? I had mine flushed/replaced last summer...should I have it reflushed and refilled?
To Does Water Wetter Actually work?
Old Apr 2, 2002 | 01:06 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Does Water Wetter Actually work? (95_C4_convertible)
If by "highside tank" you mean the radiator, YES! A turkey baster works well.
I drain, flush and change coolant every two to three years. About every third time, I use a commercial cooling system flush chemical.
Old Apr 2, 2002 | 01:42 PM
JonM's Avatar
JonM
I do mine every fall...I know its excessive...But its cheaper and less strain on the noodle if you have to change the heater core or radiator...10 bucks...its worth the piece of mind.
Old Apr 2, 2002 | 10:00 PM
Lone Ranger
Default Re: Does Water Wetter Actually work? (CFI-EFI)
Cool. I'm there!
