diy headlight motor replacement
Old Sep 29, 2010 | 10:46 PM
vetteaholic24's Avatar
vetteaholic24
Default diy headlight motor replacement
i have an 87 corvette and my headlight motor on the drivers side jus burned out and i am waiting to purchase a new one until i can figure out how to remove the motor from the headlight assembly i have searched several books and tried searching the internet to no avail i need help!!
Old Sep 29, 2010 | 11:03 PM
rodj's Avatar
rodj
Easiest to remove whole unit from car
Disconnect wires , remove bolts holding alum frame to hood , take out.
See
http://home.comcast.net/~zrjuan/head1.jpg
Undo the 13mm nut on the shaft to headlight bucket , undo 3 x 10mm bolts holding motor to frame.
Old Sep 29, 2010 | 11:12 PM
Lemme's Avatar
Lemme
St. Jude Donor '10
G'day from Singapore As an aside Rod do you know where One can get a new plastic headlight surround?
Old Oct 1, 2010 | 10:01 AM
jsinga's Avatar
jsinga
Those motors are frightfully expensive. Try and take it apart. The gears are easy to replace. As old as it is it may be full of worn out brush. Brushes can wear down to the point they won't make good contact. Just bending the springs out may get it to work.
I have been looking for brushes for the early motors for a couple of years and haven't found them yet. If anyone knows a source for just the brushes for the early headlight motors can you post it?
JS
Old Oct 1, 2010 | 12:43 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Check out this link, too.
http://www.corvettefever.com/howto/33098/index.html
Old Oct 1, 2010 | 06:51 PM
jhammons01's Avatar
jhammons01
Your answer is not in a book......however it is at the top of the page......everything you need is found in the very first sticky thread.....
Old Oct 14, 2010 | 01:51 PM
vetteaholic24
thank you very much everyone i did get the motor off and i replaced it with one i salvaged everything works great now!
To diy headlight motor replacement
